CAR WOULD NOT START
Old 10-15-2009, 05:17 PM
royalflush408's Avatar
Originally Posted by sdg1871' post='1033460' date='Oct 15 2009, 06:05 PM
My starter problem involved the failure of the solenoid. So when I tried to start it, the starter would "click" like crazy but the engine would not turn over.
I don't hear a click, but I hear a faint buzzzzz somewhere... This is annoying
Old 10-15-2009, 05:19 PM
sdg1871's Avatar
My Ride: See my signature
Ugh. Your starter sounds like a prime suspect.
Old 10-15-2009, 05:23 PM
gbaty0001's Avatar
My Ride: 2004 530i Black/ Smoked LED side markers/ CF kidney Grille/ Shadowline Trim/Miro 346 V2/General Exclaim 19"/CF Badges/H&R Sport Springs/ Koni FSD shocks/struts/R1 Concepts Drilled & Slotted Rotors/ Hawk Pads/ Mtec V2 lights/
If its not even clicking it could be your starter, or it could be something random like the grounding strap to the engine. I only mention that because the same thing happend to me.
Old 10-16-2009, 02:08 PM
stiker's Avatar
My Ride: 535d M Sport / Carbon Black Metallic / Aluminium cube / black leather sports seats / Prof. SatNav / Bluetooth.
I had a similar problem last year, sometimes starting and sometimes not - no real pattern of wet / dry / warm / cold but got worse and worse.
Changed the battery but no real improvement - read about it here and asked the dealer to look at the starter motor, they changed it under warranty and it is fixed.
The thing I remembered as the real 'tell-tale' was that the engine turned over really slowly when it did start. If you can listen to another E60 starting you will realise how slowly yours is turning over if the starter is the problem, you just get used to it working slowly when it is your car.
Good luck.
Old 10-19-2009, 10:01 AM
BuDdyLe's Avatar
My Ride: 2007 530i, Full M-Tech kit, CF Hamann front lip, M5 trunk lid, 20" iForged swift, LCI Tail Lights, Remus Quad Exhaust.
Washed my car the other day, and after about 2 hours or so the car would turn on i drive and all but could not start up, battery had somehow died out as soon as i hit the brakes. Did not leave music or anything playing either, but did have the doors open as i was going in and out cleaning the insides. But after a jump start, I got the seatbelt/airbag malfunction error so now i have to take it to the dealership to clear the code and see if I got a bad battery. Do you guys think i should put my stock tailights back on, in case they blame it on the new lci+bruce cables for some irrelevant reason???
Old 10-20-2009, 03:14 PM
BuDdyLe's Avatar
^^^^^ Got an appointment tomorrow. Anybody???
Old 10-27-2009, 06:15 PM
E92-Lighting's Avatar
My Ride: Next Gen LEDS
i believe it could be either your battery or starter
Old 10-30-2009, 12:15 PM
M3 SMGII's Avatar
My Ride: BMW E60 and F10
My garage says that my starter is also going to die. When the caris cold, it starts very slowly. With the engine is warm, no problem.
I've found a garage and he could fix it for about 150euros. He will not replace it but he can fix it he says.
Awest91
09-17-2022 11:05 PM
chadillac2000
42
09-13-2017 11:15 AM
shoryuken15
04-09-2015 03:42 PM
Stranger12
04-05-2015 10:42 AM
james69z28
03-23-2015 06:45 PM
Quick Reply: CAR WOULD NOT START
