Car/steering wheel is shaking at higher speeds badly
Originally Posted by monsterj34' post='951176' date='Jul 22 2009, 11:58 PM
mayas do need hubcentric rings as far as i know..
if you had metal hubcentric rings, maybe they worn out..
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
Originally Posted by v_therussian' post='951161' date='Jul 22 2009, 09:43 PM
Check in this order:
balancing
alignment
control arms
betcha its one of the above (hopefully, the 1st one).
GL
balancing
alignment
control arms
GL
Originally Posted by NoName545i' post='951402' date='Jul 23 2009, 05:39 AM
don't forget Bent rim, tire shop will let you know if you have a bent rim
Originally Posted by v_therussian' post='951409' date='Jul 23 2009, 02:55 AM
Yes, thanks! I thought someone may have mentioned it b4 me LOL Yes, bent rim would do that too, but also, bent rim would transfer at least some vibration at all speeds.
My Ride: 2004 545i: Silver Grey Metallic | Sports Package | | Cold Weather Package | Navigation | Tinted Windows | Adaptive Headlights | Heated rear seats| 166 rims| Matte black kidney grills|
Interior: Angel Eyes, LED license plate bulbs, HID fogs, Interior LED
Originally Posted by thegame' post='951136' date='Jul 23 2009, 12:28 AM
Hey guys,
I have a 2004 545i sport steptronic with 98500 km.
Recently I've been noticing that my steering wheel shakes when I accelerate. Now I've noticed it more often.
It starts shaking around 85 km/h and continues to shake harder the faster I go. The car shakes hard and travels up the steering wheel. But when I release the pedal when going fast the shaking/vibration stops. So basically I can drive about 80 km/h only and If I decide to go faster everything shakes.
My warranty is out and I drive highways daily so any help would be appreciated.
Thank you guys.
Thank you guys.
I had the same pjroblem, it turned out to be my tires
Just went through this, mine was caused by installing after market rims, and all the same symptoms as yours. Took them to a place that does "road force balancing" which is more accurate than the "traditional" balance. Nice thing is the machine will tell you if the rim is out of true etc. They installed hubcentric inserts (8 bucks a piece so cheap solution) and balanced all 4 to zero. Car is smooth now at all speeds! I see you're from Alberta, not sure where, I had mine done at Fast Tech Tire in Edmonton and would reccomend them highly professional and quick!
TexaZ3
May 6, 2015 09:54 AM
