Car starts normally, then as the RPM drops down to idle, it stalls!
My Ride: E60 01/04 545i - 19" Alloys
hey guys,
Its been happening more and more regularly, mainly when its warmed up and I leave it for 30 minutes or so since it was last on. It only happens about once every ten starts.
I've researched this online and I've read that it could be the IVM, but the other threads state they just get a 'click' noise, not that it starts, then dies.
other than that, the car is working great, no drop in power or anything noticable, the transmission is clunking from 2-1, but i plan on changing the oil and sump next week.
has this happened to anyone before? if so, I'd love to know the source of the problem! if its an unheard of issue, I'll try changing parts and see what fixes it for future people with this issue!![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Thanks in advance!
Thanks in advance!
My Ride: 545i
Engine: N62
Worn CCV Valves possibly? I had a similar issue, however the car never stalled. It did however feel like it was going to. Once I replaced the CCV Valves, all was well. Perform a search for CCV Valves and see if that helps.
Hey Hyper_545i,
I think you are spot on the money! I read about symptoms of the CCV Valve and my car is whistling sometimes too as described.
thank you for the help! much appreciated![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Is this the CCV Valve? It says its Pressure control valve instead, but looks identical! just want to be 100% sure before purchasing.... cheers
Crankcase OIL Seperator 2 Pressure Regulating PCV Vent Valve SET FOR BMW | eBay
Edit: I just purchased a Repair kit, pressure regulating valve 2 11127547058 $20.24
looks the same as the one above
Cheers for your help!
My Ride: 545i
Engine: N62
Hey Hyper_545i,
I purchased a pair of them ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I read a few DIY guides and I think I'll be capable of it
Again, thank you for the help! All the best,
Matt
Matt
All done!
the old ones weren't split but the rubber was much softer than the new ones. We'll see if it fixes it
cheers for the help!
thesalboy
04-08-2015 09:13 AM
