Brake service light issue
My Ride: 08' 528xi Space Gray 20' Beyers Mesh staggered
Ok, I got an issue I replaced my front Pads and rotors. but I cant get the front brake service light off, I try the steps to reset it before to reset the oil, cabin filters service light with no problems but this light wont go away. I put the key in the on position I press the odometer button I get the menu I go to the front brakes press and hold again I get the RESET? I release and press It goes from -9000 to ______
(Blank)but I get no new mileage what am I doing wrong? I've done this before. Thanks
I couldn't reset mine myself at all, so I had the mechanic that installed the brakes do it for me free of charge through the Autologic tool (I think that's what its called). Since its really kind of the fastest easiest way, I recommend you just do that instead frustrating yourself with the reset that may, or may not be successful. Just my 2 cents
My Ride: Simple and Stunning....2004 BMW 530i...Tinted Windows...More to Come !
Then I tried it 3-4 times and it actually worked , just make sure you are following the steps properly.
I was getting that ______ for first 2-3 times and then I got 40000 for my new brake pads.
Just keep pressing the tachometer button until you see your red brake sign goes orange and it displays 40000 in the window below.
Good Luck
TexaZ3
May 6, 2015 09:54 AM
thesalboy
Apr 8, 2015 09:13 AM
