Boot wont open from the outside
Old Mar 8, 2009 | 01:17 PM
Bobbydigital's Avatar
Hi guys,
Hoping someone can help me here. I have an 520i 04 (54 plate)
When I try to open my boot using the button in the recess of the boot, i can not get the boot to open. I have to turn the ignition off and use the button on the key fob- this works fine, however it is inconvienient! This has not always been an issue, just started over the weekend. Is the likely cause a blown fuse? If so anybody know which one?
many thanks
Old Mar 8, 2009 | 01:23 PM
Bilbo1's Avatar
is the car unlocked when you are trying to open it?
ktlocklear's Avatar
My Ride: '06 550i '84 Nissan S12 Turbo
I can only open mine from the trunk if all 4 doors are unlocked....if only the driver door is unlocked, I can't open the trunk from the recessed trunk pad
Old Mar 8, 2009 | 02:03 PM
DrLev99's Avatar
I might be wrong, but I don't think you can open the trunk with the car turned on using the latch on the underside of the trunk. It would be a safety issue.
Try doing it with the doors open and the ignition off. There's also a trunk release button along the driver's side footwell area.
Old Mar 8, 2009 | 02:05 PM
russdx's Avatar
My Ride: 55 525D Sport Full Black Leather Visibility Pack Media Pack
'trunk release button along the driver's side footwell area'
i was tryin to find this the other day lol
Old Mar 8, 2009 | 02:10 PM
Guys,
The car is unlocked, and I have tried all of the suggestions mentioned before posting on here. The boot will not even open without the keys in the ignition but all doors unlocked/open. This is what makes me think that a fuse may have blown?
Old Mar 8, 2009 | 02:13 PM
Bilbo1's Avatar
my '03 does not have such a button, just a plastic cover where the button is supposed to be, so i guess his is like this too
i am pretty sure you can open the trunk when the car is on, it just has to be unlocked
Old Mar 9, 2009 | 08:00 AM
Terraformer's Avatar
My Ride: 1985 325e (sold it in 1996) // 2001 Z3 2.5 / White / Blk Lthr / 5-spd (wife's) // 04 530i / Metallic Blk / Beige Lthr / 6-spd / Logic7 / 19" 166 Michelin Pilot Sp
What freaks me out is when I hit the trunk icon on my key, the alarm goes off.
Maybe this is something I can configure? Haven't looked into it but maybe the previous owner changed something. Weird.
Old Mar 9, 2009 | 11:18 AM
ktlocklear's Avatar
Holding the button too long......... I did that when I first got mine, and I would jump every time You only have to hold the button for about 1-2 secs then release, and it should open. Anything longer and it acts like a "panic" button, and the alarm will go off.
Old Mar 9, 2009 | 12:58 PM
ObD's Avatar
ObD
My Ride: 2008 535i 6MT
You may have enabled secure locking. Insert key in trunk and twist left to disable.
Securing separately
Turn the central key with remote control in
the lock of the luggage compartment lid
beyond a resistance point to the right and
withdraw it from a horizontal position.
This locks the luggage compartment lid
and disconnects it from the central locking
system.
If you then only hand over the spare key,
refer to page 26, no access is possible via
the luggage compartment lid. This is an
advantage in a hotel, for example.
Yellow Dog
Nov 25, 2019 06:27 PM
LandRange
Oct 5, 2015 08:47 AM
bestofthebest
Oct 2, 2015 03:21 PM
ucsbwsr
Sep 19, 2015 10:58 AM
Tsubasaftl
Sep 12, 2015 01:34 AM
