Battery vent tube
Old Feb 9, 2011 | 10:01 AM
mels545's Avatar
My Ride: 95 M3 CAI, chipped, pulleys, Xbrace, doesn't give headaches every time I start up! 04 545i all the goodies INCLUDING HEADACHES!
Where does the battery vent tube attach in the trunk. The tube on my factory battery is about 4 inches long on the front side of the battery. I can't find where it is to be attached so the H2 gas will be vented out of the trunk. Any pictures would definitely help.
Thanks
Old Apr 11, 2011 | 08:49 AM
jgt's Avatar
jgt
My Ride: E60
Engine: N52
Same question here. I finally got around to replacing my battery and noticed the vent tube went nowhere. I figured the battery must of shifted or something and disconnected the tube.
The vent tube was attached to the battery with a black right angle plastic connector but the other end was just pointing down...
Old Apr 11, 2011 | 09:00 AM
BestGear's Avatar
Hi - hard to describe, but on my late 2003 E60, the vent goes through the boot floor recess towards the front of the car...beside the positive terminal end - there is a grommet in the body for it to pass through a few inches up from the bottom of the battery "well".
David
Old Apr 11, 2011 | 09:14 AM
luigi524td's Avatar
The exit for the battery vent tube (so hydrogen gas doesn't build up in the trunk/boot) is nearly impossible to see unless the battery is removed. That said, be certain that it is securely connected to the battery vent port and exits the trunk.
Vman33
Mar 14, 2022 04:43 AM
ripley
DIY: Do It Yourself
Sep 19, 2015 06:21 PM
ChrizLoud
Sep 11, 2015 10:31 PM
umichchris
Sep 10, 2015 12:54 PM
lcc014
DIY: Do It Yourself
Sep 10, 2015 05:57 AM
