Sunroof Wind Deflector damaged
My Ride: BMW E60 530i, Production Date May 2005
Hi,
Was going to golf this morning and I pressed the button to raise the garage roller door.
The roller door must've stuck as I always look back while reversing and the bottom of the door didn't hit the shark fin or roof, just knocked the wind deflector.
I thought it was damaged pretty bad due to the noise it made, I just poked it down and went to golf. I've now had a better look and all seems OK except where it hinges, the shaft ends that protrude about 1/4" either side click into the recess in the sunroof frame won't click in and the wind deflector feels a little sloppy and has some forward/back play.
I'd appreciate in someone can open their sunroof and check if the metal section that protrudes from the fromt of the deflector that clicks into the frame seems to be straight or slightly curved.
I think the force of the roller door prised the wind deflector forward and bent the protruded arms that have the 1/4" hinge pins.
Cheerz
Cheerz
Hi,
From memory, the wind deflector has a fitting either side (front) with locating pins that act as the hinge.
There also is a spring tensioner that allows the deflector to rise when sunroof is opened.
You just have to exert a little rearward force to lever the hinge on either side and the spring tensioner out.
Cheerz
Cheerz
worst-case scenario, you can just remove that wind deflector and throw it away :-)
Wind deflectors are known to make noise, removing that deflector entirely from the sunroof won't cause any ill-effect.
jluzbet
Nov 7, 2015 01:25 PM
