Battery Replacing
My Ride: 2008 535i with sport package
This is a very helpful thread, but can someone walk me through the steps needed if you purchase the battery from autozone? Including battery type/specs? I have a 2008 535i that appears to need a new battery and I really do not want to pay the stealership if I can avoid it but also have everything working smooth and proper. Thanks guys!
I am looking for an A-Z explanation of what to do to get it right!
You need to do a little research. First get the model number off your battery (pull side panel off passenger side in trunk and get a flashlight. Record the number and google the number on the web and you will find equivalent numbers.
The important thing is to get the right type of battery and exact size with venting capability.
If you perform a search on this forum knowing the battery type/model number you will get exact model numbers as an example for an Autozone battery.
Question the Autozone manager to insure that they have done BMWs before because the cables cannot be man-handled or roughly pried off the battery. The positive lead contains an explosive charge that disconnects the battery if airbags are deployed in an accident. The negative lead contains a microprocessor and sensors (IBS) that is very expensive to replace if damaged. If you have any questions about the Autozone capabilities you can buy the battery and take it to an independent BMW repair shop for installation.
My Ride: 550i
Hey guys,
Just incase it helps - I've been through the process and thought I'd let you know...
2 parts to changing the battery over.
Registering the battery basically records in the system - at what point you changed the battery. i.e. 60,000 miles - 9/4/13.
Registering the battery is straight forward / done via DIS. Good if you intend of selling the car in the future.
I guess you could put a label on the top of the battery with the date/car mileage on it?
Good Luck with it.
- Programming/coding the new battery
- Registering the new battery.
Good Luck with it.
+1 Darnell Moore is correct. There are two steps in software to configuring the battery.
The first step (programming-coding) is to tell the car what type of battery you are using. BMW uses two types:
Standard lead acid battery - White case
Absorbant Glass Mat - Black case
These batteries charge differently and the computer will drive the alternator differently to charge each in an optimum fashion based upon what type is stored in the computer.
This is why I suggested that you take the battery PN off the battery and buy the same type battery as came with your car, the same color, same dimensions and the same cranking amps. Then you can skip the programming-coding step.
The second step, registration, or telling the computer how old the battery is, is then optional.
DavaiLave
08-02-2022 02:16 AM
