Battery problems
Old Feb 15, 2009 | 11:39 AM
solrac6262's Avatar
My Ride: 2012 535i M package
Originally Posted by mrfva' post='793429' date='Feb 15 2009, 04:28 PM
+1, I replaced mine with one from Batteries+ (no problems so far *knock on wood*).
you bought it from the store in Denton Frank? how much are they ?
Old Feb 15, 2009 | 11:45 AM
PraiseTheLowered's Avatar
Originally Posted by Anzafin' post='793435' date='Feb 15 2009, 12:38 PM
Like I said I replaced mine without registering, yet.
Everything works fine, it (registering) doesn't have anything to do with iDrive.
But my original battery was 90Ah and the new one is 100Ah so the registering is needed for IBS (intelligent battery sensor) so that the system can charge the battery correctly. I understand it like "calibrating" the system for new battery capacity.
that makes sense if you change it but if it is a direct swap with the same measure it shouldnt need to be registered correct?
Old Feb 15, 2009 | 11:47 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
That is how I understand it .
Old Feb 15, 2009 | 12:20 PM
solrac6262's Avatar
Tomorrow I'll call the dealer and find out how much it is..for the same battery that way I don't have to register or do anything to the car.
Old Feb 15, 2009 | 12:22 PM
Anzafin's Avatar
I guess, but what do you think THEY will tell you ?
Old Feb 15, 2009 | 12:51 PM
Sooner79's Avatar
From what I have read, if you can find an aftermarket battery with the exact same Amp Hours and the same CCA, there is no need to register it, which would essentially be telling the computer how much juice to send to the new battery to properly charge it.
Old Feb 15, 2009 | 12:54 PM
solrac6262's Avatar
yeah you are right man..
is it diferent the one on the 525i and the 545i guys, one member was selling a brand new on january but I think it was from a 545i
Old Feb 15, 2009 | 01:09 PM
Sooner79's Avatar
I believe there is a sticker on your oem battery that lists the exact AH the CCA. There seems to be no rhyme or reason as to what they use as my 325i battery has more AH and CCA than the one in my 530i.
Awest91
Sep 17, 2022 11:05 PM
DavaiLave
Aug 2, 2022 02:16 AM
DC5Series
May 3, 2015 09:15 AM
Stranger12
Apr 5, 2015 10:42 AM
E60Japanese
Mar 23, 2015 05:23 PM
