Awful squeaking...brakes?
Old 09-16-2010, 11:38 AM
healthservices's Avatar
Originally Posted by balbs
I just had full brakes done about 500 miles ago. All 4 rotors changed with R1 concept and all 4 pads (I hope they replaced all 8 not just 4)changed out with Hawk HPS pads. Still squeaks. I did the whole bedding procedure....twice. Weird thing is that it doesn't squeak in the morning. It squeaks after the brakes have warmed up and only at low speeds such as navigating in a parking structure or creeping and stopping...again, only when the car has been going for awhile.
Whoever installed the pads did not coat the pads correctly with anti seize. Either that or you drive like my grandma
I do not recommend power washing the brake components unless it is the last resort prior to removing the pads. You run the risk of removing the lube used to silence the pads to begin with.
Old 09-16-2010, 11:46 AM
balbs's Avatar
My Ride: BMW
A buddy of mine did it and he's been a professional mechanic for over 20 years and has been maintaining all my cars since high school. I saw him load the pads up with the brake pad lubricant...Yes, I meant pads on all 4 wheels (8 pads)
Old 09-16-2010, 12:32 PM
I would have him check it again, he most likely missed a spot. I have no problems with my brakes and I've only been paid as a professional tech for 15.
Old 09-16-2010, 12:36 PM
balbs's Avatar
My Ride: BMW
I watched him get it all over the place. I even made a comment about it while he was doing it. I guess I'll have him take it off and back on again anyway and reseat them....and yes, I have my kids in the car all the time so I probably do drive like a grandma.
Old 09-16-2010, 12:41 PM
Actually I'm serous about driving like a grandma. If you tend to brake early and not get brakes hot once in a while to burn of contaminates they tend to make more noise.
Old 09-16-2010, 12:43 PM
Basically any spot that the brake pad touches something should be coated, of course this does not include the face of the brake pad.where it contacts the rotor
Old 09-16-2010, 12:46 PM
balbs's Avatar
My Ride: BMW
Actually I'm serous about driving like a grandma. If you tend to brake early and not get not get brakes hot once in a while to burn of contaminates they tend to make more noise.
Hmmm...then how does that explain why it doesn't squeak when I first use the car in the morning. Driving slow out the driveway, braking slowly, no squeak...drive the car for 5 minutes and do the same slow braking back at home or work, then it squeaks. As I mention, it only squeaks at really low speeds.
Old 09-16-2010, 01:18 PM
The squeak is actually a high pitch vibration. This audible vibration happens only during certain times.
In your case it is when the pads are warm and during slow speed.
Old 09-16-2010, 01:20 PM
balbs's Avatar
My Ride: BMW
Correct.
Kaane
03-15-2022 05:16 AM
BrandonSS
10-24-2019 09:01 AM
craigm1841
The Competition
22
06-23-2009 01:50 PM
545OH
04-13-2009 07:26 PM
pharding
09-08-2005 09:42 PM
Quick Reply: Awful squeaking...brakes?
