Alignment Specs?
My Ride: Fully Loaded Monaco Blue 550i Sport
Does anyone have alignment specs for a 07 550i sport suspension?
Dealer is refusing to do a alignment on my car because it has aftermarket 20" rims so i have to take it somewhere else... does anyone have the correct specs that i can give to the alignment shop?
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
If you don't have active steering, you can take it to any tire shop. I got mine done at American Tire Depot.
The alignment specs will fall in a "range."
The problem is that the different size wheels do mess up the normal factory specs. There is a misperception that you want to go back to "original" specs. This is not always the case, although it is the safe way to go.
Boutique wheel shops are aware of these issues for all expensive makes, and they usually can give great referrals.
You definitely want to go to the same place where the alignment people are being asked to work on $150,000 cars.
My Ride: 2004 5.30i Saphire Black on Auburn, Sports Pckg, Premium Pckg, Sound Pckg, HUD, Cold Weather Pckg, Heated Rear Seats, Electronic Rear Window Shade, Foldable Rear Seats with Ski Bag, European Reflectors, Active Steering, PDC, 19" AC Schnitzer Type II, Front: 245/35, Rear: 275/30 Toyo T1S, H&R Sports Springs, 35% Tinted Windows, B&B exhaust w/ custom straight pipe
Dealers will do cars with aftermarket rims. Cuz the computer has setting for cars that are lowered and have bigger rims than factory stock. The real reason, which I found out from one of the guys over at BMW, is that in order for them to do alignment, they need 5 small holes (in between the lugs). So if your aftermarket rim doesn't have these holes, they wont do it. If you look at all bmw rims and aftermarket rims that are specifically made for BMW, you'll notice the 5 small holes
My Ride: G30 M550i
Model Year: 2018
Wheel_alignment_specifications_E60_E61_with_low_slung_sport_suspension.pdf
I appreciate all your help guys...
I had an alignment done a week ago and it wasn't done right... i took the car to the dealer and the found out the wheel bearing was shot and they replaced it.
Maybe thats why they couldn't align the car properly? im going to take it back to them and have them redo it...
Did you have it done at a regular alignment shop? Cuz I did that one time and it screwed up my alignment and steering even more. This was before I knew that you have to do active steering alignment.
PelicanParts.com
09-10-2015 10:02 AM
PelicanParts.com
08-13-2015 01:45 PM
