Airbag SGM fault 93F9 - how to fix it?
Old Feb 27, 2013 | 02:52 PM
bymer's Avatar
Originally Posted by zinchuk77
thanks man. can you share info on how you did it with WINKFP, i would like to try to clear it also. is there a write up or do you have any screenshots?
I did not do it via WINKFP, I used Progman as I was somewhat inexperienced with WINKFP, so if you have Progman, its easier that way. It will clear the code then, but not permanently. Also the cable fix, are you sure you had the 93f9 code? because as someone stated there is a whole 'nother code for that cable fix. Our code indicates a faulty module which I refuse to believe as my car has never been in any accidents or had any major faults. i cant believe that a ~1000$ module could just go bad so easily. There must be something else.
Old Feb 27, 2013 | 03:07 PM
AchtungE60's Avatar
My Ride: E60 530i
OP - I can clear the error for you permanently just PM me.
Old Feb 27, 2013 | 04:50 PM
dawid_w's Avatar
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Originally Posted by balbs
Hmmmm....You also got the 93F9 code but replacing the positive cable fixed it? I thought the code 96CA is the code for high resistance which is on the positive cable.
Hi,
You are absolutely right 96CA is the code for high resistance, but high resistance on the airbag module build in to the positive battery cable. Something inside the cable or the plug itself is getting lose causing the high resistance condition.
BMW know about this issue and for that reason they redesigned the cable in 2006.
Old Feb 27, 2013 | 05:03 PM
dawid_w's Avatar
ok, thanks for your help. is this cable hard to install, where does the other end connect, is the end of it somewhere in the trunk or does it go all the way in the car under the floor?
Cable is not that hard to install. The other end connects onthe trunk floor. You will need to remove the trim on right side, floor cover and the rear seat. There is one bolt holding the cable that is covered by the seat (which really sucks).
Old Mar 1, 2013 | 06:19 AM
zinchuk77's Avatar
Hi Achtung E60, please help me out when you get a chance with this issue. I sent a PM to you. thanks
Old Mar 14, 2013 | 04:04 PM
papu84's Avatar
have the same problem 93f9.... any updates? thanks...
Old Mar 15, 2013 | 05:54 AM
dawid_w's Avatar
Hi,
I replaced both parts (61126989780 and 61129193975) about 7 months ago. Since then never had any problems with airbag system or 93F9 error code.
GL
Old Mar 15, 2013 | 06:32 AM
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
So , u replace it and then clear the errors ? Or u clear the errors and then u replace it?
Thx u
Old Mar 15, 2013 | 02:28 PM
pcy's Avatar
pcy
Replace the cables, then clear the errors.
Old Mar 15, 2013 | 06:20 PM
dawid_w's Avatar
Hi,
I got both codes mixed up – I am sorry for all the confusion!
96CA – is the code for high resistance on battery positive cable (replace both parts 61126989780 and 61129193975)
93F9 – is the code for SGM module –from what I found you have few possible options
1. Battery is old and voltage in the car is going crazy causing this error
2. Firmware on the module needs to be updated
3. module is bad and needs to be replaced
