Adaptive Headlight System INPA error... please decipher!
My Ride: 07 550i Sports Package
My Ride: BMW E60
Model Year: 2016
Not necessarily, the AHL control modules can fail. There are two AHL modules, one for each headlight. They are located under the bottom of the headlight. I would try replacing those with used ones, you can find used ones for $40-$60. You should also try to print the INPA readout to a pdf then attach it here so we can actually see the error. There is a program called PDFLite you can use that or just do print to file.
In US, E60 with xenon comes with AHL as standard, however, this is an option in Europe. Meaning that self leveling (moving up and down), has nothing to do with SMC.
If his lights aren't doing up and down, the car auto flags it as AHL has failed, which is why I am more inclined to think that it is a case of the motor failing as opposed to the smc. Besides, this wouldn't be the first time we are hearing 2004 adaptive motor failing now. Seems to make sense, since it is a wear and tear item, and OP's car should be 10 years old.
My Ride: BMW 525dA 2007 pre-LCI.
I studied the differences between the connections of the normal and dynamic Bi-Xenon.
I believe that de dynamic module takes over the control of the self levening also. As there are less wires going from the lightmodule to the headlamp to control the motors in the dynamic versus the normal one.
As I understand it the wires controling the motor of the normal Bi-Xenon are now used by a bus system to the dynamic module which then conrols all the motors in the lamp.
You are incorrect. There are two sets under a headlight with AHL. You will see the bigger mudules which control your lights then you will see the smaller module for the AHL. Here is a part number 63127189312. Depending on the year of your car the part number could be different.
oh interesting, thank you for the clarification.
If the AHL module is out, wouldnt it cause the xenon module to stop working as well? or was it the opposite. IE: if the the xenon control module stops working so will the AHL?
My indy was telling me about this but i dont remember which way it was
clear that error again, it came together with a low battery warning. Then all sorts of warnings can come.
After clearing check if it comes again.
I do this always to verify that it wasn't a one time error or glitch.
Edit : sorry was to fast. All points towards yout AHL module beeing defective.
My Ride: 2004 545 6 M/T
Update... It was too blasted cold to go out there and remove the fog lamp bulbs. Instead I ran INPA and checked out the codes. See attached PDF's for most recent codes. Of note: PDF light2, says that the battery voltage is 11.93 volts. This is with the car "off" (but key turned to just before cranking). I checked the voltage of the battery with a multi-meter at the charging terminals under the hood (with ignition completely off) and it read 12.26 volts. Can it be that part of the error/failure is that voltage at the ALC (module?) is too low? As far as I can tell with the information I have, "alive signal of the ALC system is missing" is not getting me any closer to the culprit.
Side question... can I use INPA/OBD II with the engine actually running? So far I haven't done so?
Thank you all for your insight and information!
Please remind me (there are so many modules!) where the AHL module is located?
