550i spark plugs
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Both
Both rear plugs are difficult, but if you read a few of the guides on here and move the appropriate stuff out of the way, you'll be fine. I ended up moving my airbox out of the way, which nobody else seemed to require. This is definitely a fair-weather project and not something to do when you're in a time crunch.
Start with the front six and build up your confidence! Your sanity will appreciate nice weather and plenty of time.
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
https://5series.net/forums/e60-discu...27617/....Here is a thread I started when I was going to do my car, check out post number #3 this is what I used when I did mine, I didn't remove the air box either. Pretty easy though once I dug in. I have a 545 same procedure for 550. Good luck
My Ride: 545i
Engine: N62
I replaced mine last year @100k miles. Not hard, but as mentione cylinders 4 & 8 are right up against the firewall. Takes a bit of doing, but it can be done if patient. I used the same DIY Quarta2six posted. Good luck!
InsipidMonkey
Jun 11, 2015 01:14 PM
