550i service engine light
Old Jul 8, 2009 | 09:32 AM
SmithsonGA's Avatar
I take my 2007 550i with 46k miles to dealer due to my service engine light.
They call to keep it overnight as they have to change the thermostat and check the radiator. Ahhhh! Anyone have this issue?
Old Jul 8, 2009 | 09:36 AM
or_550i's Avatar
Nope. Not my 550. That may be the reason the service light came on. The only time the shop kept my car was when I asked them to update the software and it took over 10 hours.
Old Jul 8, 2009 | 09:43 AM
krusir's Avatar
My Ride: 2009 535xi, short shifter, no CDV
Have you ever get overheating warning before this? I would not think the thermostat and radiator will direct trigger the check engine light... However, if the two above mentioned having problem, most likely it will get engine overheat and trigger check engine.
If the true problem happens in the above two parts, overheat will be first before trigger check engine light, by that time I'd think damage already been done.
Another possibility is the minor overheating cause mis-fire .... hence the check engine, but I'd not feel it is happening.
The higher chances is the Oxygen Sensor went south.... My previous 540i consumes first set of Oxygen Sensor just right out of warranty. ( 53K miles )
Old Jul 8, 2009 | 10:16 AM
SmithsonGA's Avatar
I got no other warnings other than the check engine light. No symptoms either. Nada. I have asked the service tech the specific code that caused the check engine light, if we tells me I will update this thread.
Old Jul 8, 2009 | 10:37 AM
EBMCS03's Avatar
Thats good the more they replace now the newer your car is...
Old Jul 8, 2009 | 10:38 AM
SmithsonGA's Avatar
Ok, rep called and said the fault was the thermostat sticking. Said nothing to worry about that these cars are monitored so closely that these problems are fixed prior to major issues. No signs of any engine overheating. (btw, I couldnt find a temp reading anywhere in the instruments or idrive. The 335i rental I have has a temp gauge.
Old Jul 8, 2009 | 12:17 PM
krusir's Avatar
There is no temp gauge. Though some trick button sequences can make it show up in the display. Google is your friend if you want to know how.
I don't believe thermostat sticking will trigger check engine light directly. Anyway, as people mentioned, at this mileage ( right before warrant expire ), the more parts you get, you less you need to spend later. However, I personally don't like dealer techs touch my car .... but we have no choice sometimes.
Good side is you get more new parts in the car. Bad side is that the more stuff they replace, means either they want to make more $$ from BMW NA or they lake of trouble shooting skill, just keep replacing stuff. In later case, their work quality might in question too.
Old Jul 9, 2009 | 05:59 AM
lospice1's Avatar
My Ride: 2005 Jet Black 545i w/ sport pkg, nav, HUD
Common error code. Glad it was under warranty!
will
Old Jul 9, 2009 | 06:06 AM
Veight's Avatar
I had my 07 550 in the shop 2 weeks ago for the same fault.
I have just over 9000 miles on mine and I have had 3 check engine light errors in the past year.
The first two were exhaust sensors, and this one was a thermostat. My dealer told me it was an intermittant thermostat that was sticking once in a while and they replaced.
I also had a error with my Tire Pressure Monitor although all four tires were green on the screen. Turned out I had water in my trunk and they had to replace the module and a wire harness and the seal on the trunk. I question BMW placing sensitive electronic modules in the base of the trunk where water can get to them. Oh well all replaced under warrenty.
gergnang
Feb 2, 2021 07:29 AM
thesalboy
Apr 8, 2015 09:13 AM
2004_545i
Apr 8, 2015 04:01 AM
Sic Sticks
Mar 30, 2015 01:17 PM
blk550
Mar 14, 2015 11:02 AM
