545i oil cooler
My Ride: 04 BMW 545iA ZSP, ZCW, HUD, Silvergrau
My Ride: 545i
All he means is that there's already many places to inspect for leaks. With the addition of the cooler your just adding to the list. As long as you install the cooler properly you shouldn't have any problems with leaks around the lines or fittings. But for added piece of mind, if I were to add a cooler it would be a reliable aftermarket with braided hoses and AN fittings.
My Ride: 2005 545
I too have considered this mod. I believe a big part of the reason BMW did not put the oil cooler on the N62B44 engine is there just isn't the room in an E60 engine bay that there is in the 7 series engine bay. Having changed an alternator on a 545i I can't imagine jamming another component in there. However, I have never looked at a 550i engine, and they obviously figured out how to shoe-horn a cooler in the same engine bay (with a slightly different engine design).
I wish I could find more auto industry scientific studies regarding gasket longevity. I believe the main factors are design of the gaskets (and the 545i lacks here), heat (not good in the 545i) and condition of oil (once oil oxidizes and uses up the alkalinity of the oil additives the oil goes acidic and attacks gaskets making them brittle).
At this point I work to control the only two things I can. Keep the coolant system in good working order and use name brand full synthetic oil and change it frequently.
Regarding aftermarket oil-cooler systems I would be extremely careful to choose a system that has the highest quality fittings with steel reinforced lines and a tried and true design. If a fitting fails allowing a hose to blow off at 100 mph and dump all of your oil I venture to say you'll never pull over in time (even if you notice the dash light while concentrating on the road at high speed).
aqualibrium
07-21-2015 03:11 AM
