545i multiple faults
Old Mar 30, 2007 | 09:49 AM
M5/545i's Avatar
I have ALREADY changed my 545i battery and yet I still get these multiple system faults on my 545i from time to time. I got the same problem on my M5 and the dealer replaced the steering angle sensor (SZL) which fixed the problem. Naturally, if it's not the battery on the 545i then it must be the SZL sensor as well, however; the dealer says the 545i does not have a SZL sensor because it has active steering, is this true? Kinda makes sense since the M5 is not equipped with AS.
The dealer is still trying to figure out the problem on the 545i. Has anyone encountered such a problem wherein a NEW battery didn't fix their multiple fault problem? What could be the culprit? Most sensors are triggered when there is a sudden rise or decrease in voltage input, thus, the supposed NEW battery solution. It didn't work. Could it be the alternator? Arrrggghhh... so many sensors, so many problems!
Any advice would be greatly appreciated. Thanks!
Old Mar 30, 2007 | 05:22 PM
EBMCS03's Avatar
I'm pretty sure Active Steering cars have the SZL sensor too... it certainly sounds like thats the fault... either that or the hydraluic fluid for the active steering is low or even leaking...
Heres one thread talking about the fault also.
http://forums.e60.net/index.php?showtopic=34859
http://forums.e60.net/index.php?showtopic=27717
Old Mar 31, 2007 | 09:30 AM
M5/545i's Avatar
On top of the AS fault, I also get other faults like ABS and Tire Pressure faults, are these SZL related as well? Anyway, I'll talk to my dealer about replacing the SZL sensor. Thanks bro!
Old Mar 31, 2007 | 09:44 AM
bmw4life's Avatar
My Ride: Look At My Signature. -Other Rides and Previous Rides: 04 BMW X3 | 03 BMW 330i (Sold) | 05 BMW M3 (Gone)- 05 Infiniti G35 sedan, Premium Package, Bose Sound, HID, Sports Package, Hardwired Escort Passport x50 Blue Installed, New Transmission Installed, Navigation, Keyless Entry+Start Other Current Ride.
Hmm, the 545 active steering problem to be evident, cause my friend had one at his shop, took it in for that issue and got the problem fixed. I think they replaced the whole active steering module.
Old Mar 31, 2007 | 09:45 AM
bmw4life's Avatar
I just hope that you are still under warranty because the 545 at my friends shop was at 49500 or something, before the last service could be done.
Old Mar 31, 2007 | 09:46 AM
bmw4life's Avatar
BTW: you got a really nice m5, and welcome to the board.
sxybeemr
Jun 20, 2023 10:13 AM
Tymm
May 30, 2016 06:23 AM
subieworx
Sep 13, 2015 11:02 PM
rmendoza.2611
Sep 11, 2015 10:00 AM
Razziel J
F10 Discussion
Sep 4, 2015 01:20 PM
