535d limp mode high speeds
#21
My Ride: 535d E60 350+hp/700+nm DPF off
I was suspecting the DPF too.. because in my case, i do not remember to have reached a higher speed than 230km/h since the removal process.
Beside the actual physical removal, i also had an ECU update to ignore the DPF.
But the fact is though, there are plenty of 35d's with DPF removed that go up to 280-290km/h. So something is wrong with our cars mechanical or software.
I will try on the Dyno, with a different ECU map tuned by someone else, to see what happens. And while this, to monitor the boost level readout.
#22
My Ride: 535d
Model Year: E61 2006
#23
So turbo boost can't also be the issue because in this case it is making less than OEM max boost. If i keep the throttle all the way down from low speeds, it can go up to 250km/h. Then it goes into limp mode and i need to restart the engine to clear it.
I tried going in manual only in 6th starting from 170km/h, and the limp mode triggered around 240-250km/h, exactly as you said.
Have to restart engine, to get boost again from the big turbo.
I noticed that after clearing the ECU fault errors, with the first acceleration the car also get this error: DPF failure/failed (someth like that) - exhaust backpressure too high.
#24
My Ride: 535d
This can make some sense. Without the DPF, the exhaust flow velocity was increased alot. Once our exhaust has pressure sensors, maybe it is triggering a error due to high velocity exhaust flow and somehow it thinks that is the turbo that is making insane pressure.
#25
Have you found a solution? I tried with different ECU maps, including stock one. For maps with lower boost, the limp mode was triggered a bit higher around 240 kph.
#27
What do you mean EGR tune. You have it turned off now?
Regarding the throttle, you mean the percentage of how much the throttle pedal is being pushed down?
#28
My Ride: BMW 530d titansilver, manual transmission
BMW 535d titansilver, automatic + AMG shift Paddles
I had the same problem with my 535d (stock, 84.000km, DPF still in), and it cleared only after restarting the engine.
Will have my DPF removed this summer, as well as a new software that "eliminates" both DPF and EGR, hope that the problem will be gone.
Vlad
PS: dvdcore, esti din Romania?
Vlad
#29
@Puricele7e : Da, din Romania.
If you find other fix for the limp mode, please let me know.
I wonder though why the EGR would have an effect on the "charge-air-pressure too high" error.
#30
I forgot to mention, the following parameters are logged at the moment of the limp mode:
Coolant temperature: 100 C degrees
RPM: 3999 rpm
Gear: 5th
Boost: 2.510 bar
Injection pressure: 1638
EGR: 4%
Throttle pedal: 100%
Of course, the cause is the boost pressure of 2.510 bar , which according to my tuner should not exceed 2.3 at all.
Any ideas, which sensors are used to calculate the boost pressure level?
I suspect, part no5 (pressure sensor), in the following picture:
http://bmwfans.info/parts/catalog/E6...s_mount_parts/
RPM: 3999 rpm
Gear: 5th
Boost: 2.510 bar
EGR: 4%
