530d fluctuating revs when held at 1200rpm
My Ride: bmw 530d 2004
i have been reading about this thread which I am having same issue as mine 530d with M57N also fluctuate at 1200rpm. I was thinking maybe high pressure fuel pump regulator or may be one of injectors is playing up. I did check with ISTA and INPA as well and all the injectors seems to work fine.
hope someone will reply on this thread.
also I did check the module of fuel pump which is absolutely fine.
Shahid Mehmood Jutt (10-24-2020)
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It's an electrical/power issue you have to find. Either Alternator, compressor, battery issue. It's pulling more power than something can handle
changed glow plugs and control unit
both thermostats
alternator
new battery
gearbox service
I am thinking about high pressure fuel pump regulator 🙂.
any thoughts please??
![](https://cimg7.ibsrv.net/gimg/5series.net-vbulletin/750x1334/2756282e_8d25_4677_9d9f_ed96f9fa3673_e84452067a2623999f03d79b973e5c029c0dce0b.png)
Model Year: 05 530i
Engine: 3.0 M54
Have you serviced the gearbox? Have you tested your pump? Sadly, when you get fluctuation it's a prices of elimination. Do you have ista and INPA
I know what you mean 😞. But I don’t wanna let her go,I know she’s 16 years old now. Yeah I did service the gearbox with genuine ZF parts and I do have ISTA and INPA.
Have you got any ideas hence asking about ISTA and INPA mate?
Thanks a lot
Thanks a lot
Model Year: 05 530i
Engine: 3.0 M54
You shouldn't have and codes. I've know the map sensor, pump, alternator, battery or gearbox solve this issue. But have heard of other sensors solving RPM fluctuation issues.
