520D, both doors open warning
Ok, well keep at it. It could be a lot of things, i.e. failing module, wiring harness, etc etc.
You could also have an indy mechanic diagnose it, and then choose whether to fix it yourself or not.
My Ride: BMW E60 2.0 TDI M47
Will do! I'll try some things out now, I'll keep you updated! Thanks for replying and thanks for the tips!
So, guys. Finally I can say that the car is fixed. I always had in mind it was a module, and it was. The KGM (body gateway module) was faulty - my mechanic friend had no clue why. Changed with a new one with the exact same serial number, no coding needed - worked like a charm for one month now. Thank you for your tips - case closed!
Best Regards,
Petter
Best Regards,
Petter
