5-series Straight-line Performance Discussion
#171
I realize I have a '6, but, figuring it's a g-tech forum.........
3981lbs(including me)
.3pitch
set RPM at 1500
car had me only in it, 1/8 tank of gas
2 runs on my lunch break .
1- 0-60 with dsc off 4.91, no 1/4 mile(not enough road)
2- 0-60 4.88, chirpped 1st &2nd gear,dsc completely off, 13.14 1/4 mile, 109.77mph
328hp measured
346lb/ft tq
.76 "g's"
.........I realize the g-tech may or may not be 100% accurate, but these runs "felt" really strong as well. BTW, On these 2 I tried something a little different, I was dragging the clutch while holding her at 1500rpm, but I also had my hand on my e-brake preventing roll(kinda like power-braking it with an auto) while holding the thumb-button in, when I took off, I released the e-brake, fed the power in with the clutch, and rolled the gas pedal to the floor...(and quickly grabbed the shifter) weather was sunny, no humidity, 62 degrees,
400ft above sea level
That was fun
.3pitch
set RPM at 1500
328hp measured
346lb/ft tq
.76 "g's"
That was fun
#172
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Doesn't matter what you have. A e60 or e63, it's a BMW. ![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
Wow, that's great times. BTW, what e63 do you have? 650?
#173
whoops!... it's a 2004 645ci 6spd manual 34k miles
#174
#175
.3pitch
set RPM at 1500
328hp measured
346lb/ft tq
.76 "g's"
That was fun
.3pitch
set RPM at 1500
328hp measured
346lb/ft tq
.76 "g's"
That was fun
Oh, good times darren
I have been playing with GPS to indicated speed comparison. Since that kinda falls under Straight line performance I will post a new post in this thread and see if anybody else has done similar test.
#176
I said I was playing with the speedo calibrations and here is more info
Let me splain what you see and why. On another board we were discussing high speed runs and someone was using pics of speedo as representing "truth". When it was pointed out that the speedo reads high as a BMW policy the discussion switched to "how much" Many went off to see if they could get some GPS system to calibrate their e60 or e63. Well many of us have GPS built in so I ran some test using our internal GPS. This is pretty new data and I have not had a chance to get out someplace that is both quiet and a good road. So far I only have the "quiet" part available. The road is pretty rough so I am not comfortable going over 135 MPH so do not have any data yet over that mark. Using the idrive hidden menu to get to the "Position" page I then set about driving at the indicated speed and then take a GPS reading. These are the results. Some basic information is the BMW system, at least in my Florida east coast location, is using 8 GPS satellites in its solution. Whether that is the BMW limit or only what satellites are visible at that time of day I do not know. I will check on the number visible latter. But eight will produce a very accurate solution. Other factors, it appears that setting a speed may vary at least by +/- 0.5 mpg. Sometimes I go on high side and come down, take a measurement, and then come from under the desired speed and take another measurement. These vary from time to time. What I have done is to accept the ones that best fit a particular curve. Now looking at the data you will see significant steps. Are these GPS related or BMW algorithm related as they designed the speedo calibration. Again, I do not know. If others could contribute to this study we might formulate a reasonable hypothesis. Anyway here is the chart. The data represents the difference in MPH between the speedo reading and internal GPS reading with the speedo ALWAYS higher.
I also have included a sample GPS readout.
![5-series Straight-line Performance Discussion-speedo_vs_gps.jpg](https://5series.net/forums/attachments/e60-discussion-2/32855d1482365069t-5-series-straight-line-performance-discussion-speedo_vs_gps.jpg)
![5-series Straight-line Performance Discussion-idrive_gps_screen.jpg](https://5series.net/forums/attachments/e60-discussion-2/32856d1482365069t-5-series-straight-line-performance-discussion-idrive_gps_screen.jpg)
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
