5 Series BMW Windscreen wipers
My Ride: 5 series BMW
hi I have a 2008 5 series BMW M sport, the wipers have stopped working in the upwards position, I have already replaced the fuses the brown relay switch and the wiper motor and wiper switch but it's still not working, does anyone know how to fix the issue? thanks in advance, Fergus
Engine: N54
Hi Fergus
I also have a 2008 535 and have not seen anything like you describe. Do you have any new information on this problem yet?
My Ride: E60 2010 535i /FBO
Model Year: 2010
Had to get me a bee motor. Used 55 bucks. Install was a pain . Did the same ,fuse,relay... it's the motor most likely..unless u have have the wipers stuck in position. There is a you tube out there on how to to fix. Good luck
Model Year: 2010
Sorry ,did not see u already got motor. Power getting there???
