3rd day of ownership, overheated and left me and my son stranded
My Ride: 2006 BMW 550i
thanks actually got news it is the wp and they doing the thermostat as well. $1000 job and dealer where i bought from is standing behind it and cutting me a check tomorrow. good news right?? one question and i've looked but doing these 2 components, will they have to take the radiator out and or expansion tank? I figure if most the labor is being paid for i will spring for the additional components to give me piece of mind.
i doubt they'll replace the hoses. and its not a bad idea to change the oil.
kudos to you mr turbo you were 100% correct however they did did replace some screws. friggon $15 for them too. oh well after 4 hrs of driving shes back, and better them ever. thanks to all
My Ride: '08 E60 535xi, '07 E83 X3
Do you have full maintenance history for this car? I would look at it to see what else needs to be addressed. At 90k miles is where the real maintenance starts if the car was following just the recommended BMW service guidelines. FYI, your engine rough engine displacement is indicated by the model. 530 - 3.0 liter, 545 - 4.5 liter, etc... From that we can deduct if it's a I6 or V8. But coming from the E39 you probably already know this. Good luck with your car.
Can someone chime in, as I'm also new to the E60 chassis, but battery issues should not affect the power while driving, can they? The alternator at this point is proving the juice. Heads up display fading? You are aware that wearing polarized sun-glasses will cause display 'fading' depending on how the glasses are oriented. (took me couple of days to notice that) Losing power to me indicates that the car was already overheating and the ECU was reducing the throttle to save the engine. You should also see a warning on your cluster telling you to shut off the engine.
I remember looking at carfax and car was maintained at every interval and at the same dealership. i actually asked for a copy of the past records today just to have in my file to refer to. well i obviously got the wp and thermostat done now and new coolant... had them do oil as well. at 100k im do for brakes and spark plugs. tranny fluid? some say never, some say replace. what else should be checked or performed?
DavaiLave
08-02-2022 02:16 AM
