3K 535i Project
#21
Banned
My Ride: 535i
While waiting on more parts I worked on the harness. Stupid crank sensor plug snapped in half. Ordered a new connector and crimped new pins.
![](https://lh3.googleusercontent.com/ykzyvNqm6NciEkcgLQ4-9WSYM911o6N599bLXAg36Ii2T2xplW8LgcgHrJSStpknByXJVNk8pzUAC61MeT5SegMjckTz8ZUw4db3Vzo_1Nr1woBvYQDFTAGfELDWeJz0QfNt7J-s0A=w2400)
All done.
![](https://lh3.googleusercontent.com/JQtQf43tM-85jyOiV5E8L6Pe81KJVs9N14vj5-resNSjrS4lliAmhkP4mAoFdByVs2QcNHZi2iHrMxa62_liDMzVTKWBkbBPMMDvhEvd3JgPw3Kjx9npox2fk9bBfIEvVg68dO0yEw=w2400)
Suspension parts started arriving. Got Koni Actives, new strut mount, new swaybar endlinks and lower control arm. Thrust arm looks ok, so I did not order one.
All done.
#22
Banned
My Ride: 535i
My turbosmart diverter valves and new charge pipe showed up today. Also picked up a new spring compressor, tired of using the deathsticks. I can remove springs in 30 seconds now ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
![](https://lh3.googleusercontent.com/7dvfq2mW4y3hk4Bobmr9lcCvsbXmA9QFQmJF7Ql6nhvrHmhNI6_VyRMvc42yv3h2zPThrW0UjesRSwIKHDsFDxQwgcgTKPbn5ooVKnIT1FSuFzTGz5o-j3Kw0M_OFy9zjrj9BawycQ=w2400)
#24
Banned
My Ride: 535i
#26
Banned
My Ride: 535i
Correct that is e60 specific charge pipe. I used turbosmart on some other projects and I think they are top notch, never gave me any problems. Forge is not a bad option either.
#27
Please let us know if you have any fitment or other issues with these. Thanks.
#28
Banned
My Ride: 535i
Weird. I checked Car Lab's website but didn't see an e60 application. So this would be the only other e60-specific charge pipe aside from Evolution Racewerks. I'm also leaning towards the Turbosmart. It seems that the Forge DVs may require regular maintenance (e.g., every couple of months) or they might start sticking. Hopefully, Turbosmart doesn't. Haven't come across many reviews of N54 Turbosmart DVs, mostly Forge.
https://www.ftpmotorsport.com.tw/pro...5i-charge-pipe
#29
Banned
My Ride: 535i
Started assembling the suspension. Got all the pieces for the struts. New spring pads, bellows, bump stops and strut mount.
Old and Busted
![](https://lh3.googleusercontent.com/IB9O2UwRqhoIQ5cBgepBcgVbBYqZovnJpKLYA1tvklpVdUycZ_RubkmRdRcYQjnenNCMkHlagp__SL6UuIhf3fK6rfaLaXDHiiHFuiYuQ42EOX3NuKI2sSp4vtLrwPKIMzdo-hdj7Q=w2400)
New Shiny
![](https://lh3.googleusercontent.com/qZapgo1Ek1Rr3PzSCQJ6HYxCENOWvAVO_2zbSHyeVWwql2V4GsYMUScbTSvQQsSJeRNq7DGdxgmCyK8oseOjr9pGg1w5EI67gXMGrpFuhUvucHWTk3JY_za5DmmgJmDXC144durKdg=w2400)
All put together.
Old and Busted
New Shiny
All put together.
#30
Your posts are about the only good thing about facebook. Took me awhile to place the names.
Really dig your posts.
Bimmergeeks protool facebook is also good.
