3K 535i Project
Just picked up this 2008 535i with 110k miles. Its a bit rough, but hey it was only $3k.
I've had one just like that couple years ago, but it was flooded due to clogged sunroof drains and totaled. Car has a sport package, PDC, heated seats. No Nav though and no Sport Transmission. Speaking of transmission, it's toast like 10 separate codes. Thus the reason for the cheap price. Interior is not bad, just needs cleaning. Exterior has some scratches, but nothing major. Its sitting on some lowering springs, no idea what kind. Exhaust vanos code, so runs a bit rough at idle. Leaking from oil cooler housing. Goal is to clean it up, rebuild or replace the transmission, throw some downpipes and intercooler and have a nice backup daily. Some pics. https://lh3.googleusercontent.com/Pp...SrSEYwsg=w2400 https://lh3.googleusercontent.com/HE...epKPO7Sg=w2400 https://lh3.googleusercontent.com/xK..._AW7-t3Q=w2400 https://lh3.googleusercontent.com/oY...fKJcBIFw=w2400 |
Worked on the car last few weeks. Put it on my lift and started doing a once over.
Here is a list of issues.
Today I was finally able to fire it up and go for a drive. Engine runs smooth, but injectors are loud and I have a +30 long term fuel trim on bank 1. I also have Index 9 injectors on the same bank and Index 11 on Bank 2, so seems those are failing. I ordered 3 new injectors. Best part is transmission works perfectly, just that stupid sealing bridge made it not shift. Next is the suspension, install a new valve cover since the old one is pretty beat up and I am sure the PCV ports are all clogged. Once I deem it road worthy I can start some minor upgrades :) Car on lift finally https://lh3.googleusercontent.com/iW...9fB1qpKg=w2400 Wrecked control arm bushings https://lh3.googleusercontent.com/Vv...k65I9MRA=w2400 Valves Before https://lh3.googleusercontent.com/XU...2MB6E9hw=w2400 Valves After https://lh3.googleusercontent.com/dr...IPP_t-5g=w2400 Broken vacuum hoses https://lh3.googleusercontent.com/QS...cf2bG9Pg=w2400 Valvebody Out https://lh3.googleusercontent.com/Fs...gCSBvY2w=w2400 Transmission rebuild or buy a $12 part? lol https://lh3.googleusercontent.com/NM...40z1IsEg=w2400 Oil filter housing getting cleaned https://lh3.googleusercontent.com/e_...ZK5mya5g=w2400 While waiting for FCP Euro to deliver my parts I found some cheap wheels for my parts delivery wagon, could not pass them up for $200, my old silverado almost looks modern lol. https://lh3.googleusercontent.com/Wl...3QB9x2sw=w2400 Transmission parts https://lh3.googleusercontent.com/kT...n4vyEp_g=w2400 |
Nice work! What's the ceiling height in your car hole? I want a lift and have 11 foot ceilings.
My ceiling is a bit less than 12 feet, its a bit sloped. I can stand under the car with it being at the highest point.
Great post, thanks! |
Originally Posted by Kaane
(Post 1598135)
Unfortunately project is getting more complicated. After I put it back together I am still getting a flare between 3 and 4th gear. It most likely has issues with the E-clutch. Also the oil pain leaking pretty badly. Since transmission will have to come out for a rebuild, I decided to just pull the motor and fix all the leaks at once.
While taking the front end apart, I noticed water pump bolt completely loose. The waste gate actuator was missing 1 bolt.... No idea who worked on it in the past but they cut some corners. https://lh3.googleusercontent.com/6_...zidKUErQ=w2400 |
i'm so jealous of your lift.
gook luck with the overhaul. |
Motor is out. Super filthy.
Motor mounts are completely shot. Wastegates worn out as well, will need replacing. Decided on the 6MT swap and dynamic drive delete, going to install M5 Sway Bars as well. https://lh3.googleusercontent.com/1I...pG540D6g=w2400 |
I think I need new wastegates.
Also motor mounts lol. |
