2E8E code after replacing IBS
KavanaghUSAF (07-16-2022)
My Ride: 535xi 6sp manual
However, depending on the task I may do it, or may not do it if it requires a lift / garage where the problem is.
Oh, I didn't say I fix everything. My time is worth money, and so if it's cheaper timewise for my indy mechanic to fix it, I will gladly pay him.
*SOLVED*
Battery needed to be coded again…
Apparently the coding through Protool and MHD didn’t register the battery correctly, battery was recoded at the shop.
If you don't register the battery, it does not throw any code, it just won't maintain your battery properly over time. Still sounds more like an iffy connection or IBS. I'm not just trying to be right, but that fix just doesn't make sense.
Persian_535i
12-16-2012 04:48 PM
