2882 Mixture Preparation Bank 1
Old Aug 22, 2021 | 11:44 AM
dv8ed's Avatar
Default 2882 Mixture Preparation Bank 1
I’m getting a service engine soon increased emissions light. Anyone know what screenshot means? Is it CCV PCV causing it?
Old Aug 22, 2021 | 12:19 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
You have a vacuum leak. I would do a smoke test to pin point it. If you have not changed the PCV system before plan on doing it also if it's not where your leak is. I would recommend to not change one part plan one changing them all because if they are old you will break a hose replacing just one piece.
You didn't post your year and model so I can't help you any further
Old Aug 22, 2021 | 01:04 PM
dv8ed's Avatar
2004 525i 215,000K miles
PCV was changed 9/4/19 at 187,000 miles. Intake boot and fuel injection idle air control valve gasket was genuine everything else OE or Rein.
Old Aug 22, 2021 | 02:36 PM
Just the PCV and not the whole system? I would do a smoke test and proceed with what you find. If only the PCV was replaced there's a good chance the tubes are your corporate or the intake boot. I am not suggesting you just change parts. I am suggesting you diagnose with a smoke test first then go forward.
Old Aug 22, 2021 | 04:49 PM
dv8ed's Avatar
It was PCV kit from fcpeuro. Smoke test was done 2 times there’s no leaks. I’m going to replace PCV kit again.
Old Aug 22, 2021 | 05:11 PM
donpb's Avatar
My Ride: '06 530i N52
Is it possible to pass a smoke test but still have a vacuum leak?
Old Aug 22, 2021 | 10:15 PM
If it's done correctly then no. If there is a noticeable leak you will see smoke.
BET530
Jun 28, 2011 08:32 AM
NY STATE OF MIND
Aug 1, 2010 05:52 AM
ldesouza
Sep 21, 2009 12:18 PM
Veight
Jul 22, 2009 07:48 AM
SmithsonGA
Jul 9, 2009 06:06 AM
