2008 528i Auto Popping Out of Gear
Old Nov 22, 2024 | 06:34 PM
Lgodbey's Avatar
My Ride: 2008 528i
Default 2008 528i Auto Popping Out of Gear
Hey all I have a 2008 528i that when driving will go into neutral quite frequently with no warning. No error messages or anything. I was able to get a code E09A. Anyone have any ideas? I have done a fluid and filter change.
Old Nov 22, 2024 | 06:40 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Time for a gear shifter
Old Nov 28, 2024 | 05:01 PM
Lgodbey's Avatar
My Ride: 2008 528i
Got a different shifter and it did not change how the car was acting. It is still popping into neutral after driving for about a minute. I can then pull it back towards drive and it will continue for maybe 10-30 seconds then pop out again. Then it may be ok for a little but and do it again. Any idea what could cause this.
Old Dec 10, 2024 | 11:55 AM
Acalab1's Avatar
My Ride: 2008 E60 N52k white 528i
Engine: N52k
Try resetting your transmission. Turn the car on to radio ready, but do not start your engine. Press and hold down the gas pedal to the floor for about 30 seconds. Turn car off, open and close driver door and your transmission should be reset. I have a 2008 528i as well and had issues with shifting out of drive or not shifting into gear at all..after a while. It turned out that I was almost bone dry on transmission oil. Someone before me took the car to a whack mechanic who siliconed the drain plug on the transmission pan. This over time, caused a slow leak and when I bought the car I was nearing that transmission almost being completely without fluid! So I've replaced the pan so no more drain plug leak, added the fluid back in and the car has been running fine with no shifting issues ever since.
rags2repair
Sep 4, 2024 07:29 AM
User 92191
Sep 10, 2021 02:11 PM
altecsonyc
Apr 12, 2016 05:02 AM
zakt
Apr 20, 2013 02:28 PM
Rix Mix
Jan 16, 2007 11:27 AM
