2006 bmw 530i 207,578 miles
It's 10:54 pm I just went outside put the key in the ignition interior lights came on turned the key nothing it has been on a charger for 3 days by the terminals under the hood battery dead now moved charger to the battery . Wondering if the battery cables are bad I'm at witts end now can't read codes no power new battery and charger its dead my brain hurts . Thank you to everyone helping I appreciate it
I requested that you test the charging system. If you did that, then share your results for nominal voltage, charging voltage, load test, IBS, battery charge status, histogram and parasitic current draw,
