2006 535d M Sport - Servotronic Failure
Old Oct 12, 2025 | 03:09 AM
BBM5's Avatar
My Ride: 2006 E60 535d M Sport Titanium Silver. Options (Visibility Pack, Media Pack, Comfort Seats, Active Front Seat Ventilation). Evolve Automotive Remap (340 bhp).
Default 2006 535d M Sport - Servotronic Failure
Hi All,
I've got a 2006 535d M Sport (UK Right hand Drive). I've got a Servotronic Failure fault and the steering is heavy and unassisted. My local BMW Independent has been trying to diagnose the root cause for a few weeks now and is at a loss. The following have been replaced yet the issue still persists.
  • Hydraulic Steering pump replaced.
  • Solenoid replaced with (OEM non-BMW).
  • Electronic Control Unit (replaced with used one...fixed the issue until car was restarted then fault came back).
  • Checked the wiring loom for shorts, this checks out fine.
Any other suggestions on things they could check?
Old Oct 12, 2025 | 05:52 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
What are the errors? This should be simple to install with the proper software
Old Oct 12, 2025 | 05:00 PM
BBM5's Avatar
These are the current fault codes on the car. INSTRUMENT CLUSTER (INSTR) (komb60)
1 fault
A559 Instrument cluster: Power supply switched off
INTEGRATED AUTOMATIC HEATING/AIRCONDITIONING (IHKA) (ihka60)
2 Faults
9C54 AUC Sensor
9C55 Fogging sensor
SAFETY AND GATEWAY (ZGM) / BODYGATEWAY MODULE (KGM) (kgm_60)
1 fault
93C1 Servotronic: Hardware faulty
CAR ACCESS SYSTEM (CAS)
1 fault
A0B0 Input, brake lights, implausible
DIGITAL MOTOR/DIESEL ELECTRONICS(DME/DDE) (d60m57d0)
7 Faults
4222 Glow plug, cylinder 2, activation
4252 Glow plug, cylinder 5, activation
4262 Glow plug, cylinder 6, activation
480A Particulate filter system
481A Particulate filter system
4B10 Smooth running controller
4687 Throttle valve actuator
Old Oct 12, 2025 | 05:36 PM
Looks like you've done everything that you should have done to fix this issue. Most of the time it's either the sensor or the wiring. Once all the parts were replaced programming and coding with a calibration should have been done and that's it.
Old Nov 24, 2025 | 05:57 PM
BBM5's Avatar
Steering calibration didn’t solve the issue.
They tried to update the software. The first attempt to program it failed and it suggested carrying out a battery reset before a 2nd attempt. A battery reset is basically disconnecting the battery for 10 minutes or more. So they did this but the 2nd attempt also failed and now there is a permanent fault code stored in the DSC for "ECU Internal Fault".
Any suggestions?
Old Nov 25, 2025 | 06:56 AM
Is this at the dealership? Seems like they are clueless and now damaged the DSC. Maybe just flashing the DSC will get it back working but they don't have the tools for that. Also did they check the ZGM flexrays to ensure the port was not closed. Probably something they can't do at the dealer level. I would also suggest checking the SZL as that may be the cause of everything. If proper Diag was done a wiring was deemed good the SZL would be my guess if the servo is indeed good
Old Dec 16, 2025 | 11:13 AM
BBM5's Avatar
No this is at a bmw independent specialist.
I’ve got the car back, they ran out of ideas. Power steering still doesn’t work, but there are no faults on the dash anymore. Haven’t got a code reader to read the codes.
P444UL_R
Apr 14, 2008 07:41 AM
CarloTT
Apr 6, 2008 01:49 PM
Merv the Derv
Oct 27, 2005 10:40 AM
ISUK
May 20, 2005 07:10 AM
Merv the Derv
Apr 1, 2005 11:27 AM
