2006 530i overheating!
Old 07-07-2011, 06:07 PM
HiOffcr's Avatar
My Ride: 05 545i 19" MRR GT1 Interior LED retrofit
Have you checked the actual operating temp of the engine when you get the code? It may be throwing the code without actually overheating.
Old 07-07-2011, 09:35 PM
ta0sum's Avatar
yeah i used my obd2 scanner and deleted the code and now the car isnt throwing any code but the car is still saying "engine to hot drive moderate blah blah blah..fuck im soo effen suck here guys.. i did a coolant bleed and still no good --> heres a link if anyone wants to bleed their system http://forums.bimmerforums.com/forum.../t-709073.html
Old 07-08-2011, 06:05 PM
txag_530i's Avatar
There are two sensors for the cooling system:
A temperature sensor at the radiator outlet
A temperature sensor located at the thermostat
Try going here to review the wiring diagram which may shed some light on the operation of the system.
BMW Wiring Diagrams
Old 07-09-2011, 08:42 PM
ta0sum's Avatar
okay the car is in the shop and ill keep you guys update whenever i can... just for future problems
Old 08-04-2011, 09:37 PM
ta0sum's Avatar
Okay i found out it was a the expansion tank.. i used my cousin tank and it stopped overheating and the coolant bleeding process is super messy!1st- i took off the cap for the tank and turned on my car until the water overflow out once it over flow wait 2 secong and then turn off the car.. repeat the process and keep topping off the tank..
iNDOLiFE
07-13-2015 06:20 AM
ROCKITMAN
07-13-2015 02:16 AM
jcolley
07-11-2015 05:39 PM
Mihainede85
07-07-2015 09:32 PM
DAVE H
07-06-2015 12:27 PM
Quick Reply: 2006 530i overheating!
