2004 545i Shaky / Pulse movement
Old Feb 29, 2012 | 01:58 PM
  #21
AchtungE60's Avatar
My Ride: E60 530i
Originally Posted by 2004BMW545i
I will look into this Flex Disc. It may be worth checking into. After googling what it does, seems like it may be the problem or at least some of the problem. Thanks!
This could be the issue but getting to it is difficult. and you can probably examine it if you get the car on a lift. The guibo is incredibly strong. A while back I had both BMW and an INDY tell me I had to replace the shifter bushings on the car and the INDY told me my driveshaft is bent and I might as well replace the flex disc too. So I got a new driveshaft and all the other goodies and did it. I did not have a press for the driveshaft so I took it locally and had them press it. They asked me why im changing it and i told them...they said nothing wrong with driveshaft and offered to buy it from me so what the hell I sold it because i alrready got a new one and had them take some sleeve from it. what a joke. So anyway I put it all back together and that was that. Didn't fix issue but I did have a short shifter that I put in there....I mean SHORT so that was cool until a few months later when someone smacked me and pushed my trunk into passenger seat. RIP
Point is... you may listen to people and spend a ton to never fix. If I were you, just do a visual inspection first before doing anything. Have you looked at your engine mounts. How is your stop and go do you feel any jerk or shake? Check into those, do a visual inspection.
What is the difference from when the car is creeping and moving? The engine is already in a "strained position" so you may not feel anything but if it's loose you would feel it while taking off or punching or stopping abruptly. The manifold is also electronically controlled. I do not know much about the 545 but I do know BMW and most of these cars have electronically controlled manifolds. At low RPM you are electronically limiting the manifold while when you are above 1000-1500 RPM you are most likely Fully Open. Think of a butterfly valve. I hope you get it sorted out.
Old Mar 1, 2012 | 06:01 AM
  #22
2004BMW545i's Avatar
Thanks for the advice. I will post updates whenever I can get around to looking into it.
Old Mar 1, 2012 | 01:45 PM
  #23
hooch999's Avatar
My Ride: 550i
Can you show me a diagram of the CV joint now?
You're sitting here with 80 posts ..
Look at item 17 at that diagram - you will find where CV joint is on RWD vehicle you moron with 1000 useless posts.
Zimo
Apr 11, 2018 08:25 PM
tommyboy
Aug 3, 2015 03:06 PM
kneemah
Jul 27, 2015 02:06 PM
milkox
Jul 15, 2015 09:48 AM
Deano
Jul 9, 2015 08:47 PM
