08 535xi u0100
Old Dec 16, 2020 | 11:50 AM
jadidaskv's Avatar
My Ride: 08 535xi
Default 08 535xi u0100
So last month a couple times when it was real cold i would have to use a jump pack to start the car.
2 weeks ago i put a new battery. Today its pretty cold and wouldnt start again. i was in a rush so i used the jump pack and started it up and drove fine. Couple minutes later i realized the CEL was on. Got home left it running, used my cheap scanner and got that code.
Tried to clear it but wouldnt clear. I shut it off and started it a couple times and started fine but the CEL stayed and still wouldnt clear when i tried to clear it when it was running or just key on.
Car has 186k and i have a wrx that i need to finish an engine swap on so the battery i got was a reman interstate since i wont be driving this car much once i finish the wrx engine swap.
Old Dec 16, 2020 | 01:30 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Looks like you need another battery to me and register it
Old Dec 16, 2020 | 02:03 PM
donpb's Avatar
My Ride: '06 530i N52
And the code you got was?
A cheapy code reader cannot read or clear BMW specific codes.
Old Dec 17, 2020 | 02:23 PM
jadidaskv's Avatar
My Ride: 08 535xi
Ya im thinking another battery as well. Its got a warranty so ill bring it back n swap it out.
Ive got codes with it before on this car. This u0100 code was something like failure to connect to pcm or something along those lines, i forget the exact wording. Last time i hooked my snap on scanner to this car i wouldnt pull codes. It IDed the car and a couple other things but wouldnt pull the codes.
Last night it started on its own and the CEL wasnt on. Today got over a foot of snow and it wouldnt start again.
Old Dec 18, 2020 | 11:02 AM
donpb's Avatar
If your battery and / or charging feedback loop has issues, you're going to get potentially unrelated codes.
Prof
Nov 14, 2020 09:01 AM
Enrique.79
Dec 18, 2018 05:46 AM
Johntee540
May 26, 2017 04:06 PM
0utf1t
Jan 7, 2015 01:44 AM
E61530XiTnCT
Mar 5, 2012 07:49 AM
