06 e-60 slight jerk when coming to full stop sometimes
My Ride: bmw 530i
I own a 06 530i last week I started to notice when coming to a full stop the car sometimes after stopping it has a slight jerk or should I say nudge forward it feels like its in the transmission ,has anybody had this problem before , and what was the solution to this problem ?
How many miles on the car? Has the transmission ever been serviced?
Have you checked if there are any trans fluid leaks, especially around the electrical connector sleeve?
It's called a bump downshift and it's a common issue on the ZF 6HPXX transmissions in BMWs as they age. The issue could be as simple as low fluid level from a leaking mechatronic sleeve, as stated above. Fresh fluid, filter/pan, sealing sleeve and resetting adaptions on the TCU may take care of the issue. It may require solenoid or complete valve body replacement. The best course of action is to try the first procedure and see if that fixes the issue and then proceed from there. Check out KyleB's 6HP19 DIY in the DIY section on this forum. Tons of information there.
My Ride: 06' BMW 525i
do these cars have LSD? my 13' camaro had LSD and the clutches in the rear-end did the same thing you diecribed, and that was a stick shift.
My Ride: 550i
Model Year: 2010
no LSD...only the "eLSD" that the DSC tries to emulate. It's caused by the transmission downshifting from 2-1 when it's cold. Mine went away after I changed the fluid.
TexaZ3
05-06-2015 09:54 AM
