04 530 AEs not wroking
Need some help in diagnosing the problem. I had an indy shop try to make my angels as drl. They connected autologic to the car and could not find any settings to do what i wanted. Now the angels do not turn on in any setting. The tech hooked up a battery charger to the car which was turned off to do the coding. I got the car back and now no more angels.
Any ideas? Is there a fuse that they might have blown? If it was a fuse there should have been a fault code no?
Thanks!
J
Thanks!
J
My Ride: BMW E60
Model Year: 2016
You should have asked us first if not read around the board. You can't set your angel eyes as DRL on your 2004 unless for whatever reason you had upgraded to light module 2.
Now as for your problem, I am not aware of any fuse for the angel eyes. There's basically two things to do, have someone with NCSexpert look over the trace file of your LMA module, and check your bulbs to see if they're out (somehow).
You wont find any settings in auto-logic to do what you're attempting to do because it doesn't exist and you can't do it without modifying the car physically.
Cannot be done by coding. This feature is just not worth it.
Bank$hot530
09-16-2015 01:28 PM
