What brake light bulbs for LCI tails?
Old 06-24-2011, 01:02 PM
  #71
bruce_miranda's Avatar
Originally Posted by tsaros
I have done the bulbs swap now and it´s the bulb closest to the foglights that is causing the errors, the outer brakebulbs does not cause any errors, only the ones beside the fogbulbs.
Do these bulbs even come on when you brake because if you are in the EU then I don't think they do. Can you confirm that. These bulbs are your BFD lights and at normal times are only acting as Tail lights.
Old 06-24-2011, 01:10 PM
  #72
tsaros's Avatar
My Ride: 535d -08 lots of goodies 120dA -06
They all light up when braking, when not braking they are not lit at all, my only tail lights are the rods.
Old 06-24-2011, 10:58 PM
  #73
Do you have an LCI car then?
Old 06-24-2011, 11:17 PM
  #74
Ehssan's Avatar
My Ride: Many BMW's
Yes he has LM2
Let me check your trc file and compare it with mine .
i will get back to you in a bit
Old 06-25-2011, 12:11 AM
  #75
Ehssan's Avatar
My Ride: Many BMW's
Update :: I've checked and compared your trc file with mine , according to your trc file ,, you have disabled everything related to taillights bulb and you should not get any error what so ever even if you remove the bulbs completely , I'm sorry but I don't really have any background about your NCS skills , but are you sure you are coding the car with the updated .MAN file or you just read trc file , do the changes and save the file ,, I apologize if I sound silly but I've seen it a lot ,,
Old 06-25-2011, 12:23 AM
  #76
tsaros's Avatar
Bruce: Yes my car is a LCI car from the factory, manufactured 2008-07.
Ehssan; The outer bulbs can be removed without any problems, it´s the bulbs closest to the fogs are causing the errors,
No need to apologize, the question is valid, yes the car has been updated with the file i posted
I have done the front turnsignals, indicators in the HUD etc so i do belive that i have the procedure covered.
Old 06-25-2011, 05:31 AM
  #77
Ehssan's Avatar
My Ride: Many BMW's
very strange . i have done several lm1 lci taillights upgrades and as bruce said , it works well ..
Old 06-25-2011, 08:42 AM
  #78
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Yeah, I don't know guys, I have tried this for both pre and LCI, and it has never worked in two scenarios 1) removed bulbs 2) replaced bulbs with LEDs.
They only way that I have been able to eliminate the error was by using resistors or modifying the circuit with diodes.
I have tried this on my car, on a 2007 M5, a 2008 528, a 2008 M5, and so forth.
Old 06-25-2011, 11:05 PM
  #79
Ehssan's Avatar
My Ride: Many BMW's
Actually while comparing my trc file with tsaros trc file ,, I found a lot of BFD options was activated for all the taillights bulbs , which is disabled in mine except the rear FOG ,, not sure if this is related to that ,,
tsaros : once I'm back from work , I will post the values which are different than mine , try it , you never know ..
Old 07-10-2011, 03:03 AM
  #80
tsaros's Avatar
Did you guys give up on me?
Quick Reply: What brake light bulbs for LCI tails?
