Upgrading of my Business to Professional Navigation
CONGRATULATIONS!!!!
From what I've heard, I think you were very lucky in having those ebay purchased parts work right away (Pretty much like plug and play from what you are saying).
I have no NAV and no NAV wiring and doing NAV Prof. retrofit has been my dream ever since I bought her. Could you post a list of parts that you used (Each individual BMW part number) if possible?
Good luck with the CIP software update
My Ride: BMW E60 530i, Production Date May 2005
Originally Posted by Wiu-Bimmer' post='388341' date='Feb 8 2007, 02:52 AM
CONGRATULATIONS!!!!
I've attached the Professional Navigation Retrofit install instruction, you'll need all the parts listed.
Cheerz
Originally Posted by daMANiack' post='388575' date='Feb 8 2007, 03:31 AM
Hi,
Cheerz
Cheerz
Did you kept or, do you remember the part numbers of the CCC and monitor and/or the production dates?
Thanks
Nick
Originally Posted by nicke60gre' post='388599' date='Feb 8 2007, 11:31 AM
Hi,
Thanks
Nick
Thanks
Nick
I think my CCC was 65839117559, but RealOEM only shows 65839123087. The CCC was manufactured on 26-3-2006.
http://www.realoem.com/bmw/showparts.do?mo...;fg=45&hl=3
and the 8.8" monitor looks like, Real OEM says 65826973546. The 8.8" monitor has a production date of 48/04
http://www.realoem.com/bmw/showparts.do?mo...fg=50&hl=15
I must say I was a little disappointed with the look of the 8.8" as it had scratches on the perspex front cover. After a little research, I decided to use SILVO to remove the scratch, and a product called PLEXUS that kinda fills slight scratches, and polishes when you buff off. After looking at my 6.5" monitor I took out, I was surprised that it also had scratches on it. Polishing the perspex front hasn't caused any reflection issues at all and looks brand new.
Cheerz
Originally Posted by Bambi' post='389149' date='Feb 9 2007, 04:11 PM
Is the eBay seller called something like amador?
That's him, amador143.
Code:
http://search.ebay.com.au/_W0QQfgtpZ1QQfrppZ25QQsassZamador143
Wow, he's got all the parts selling for 1,800 EUR
If you are in the US, I think you can get a better deal from Garry (BMW of Newport). Besides, if your car is US specs, these parts from ebay might not even work (Since they are for EU specs cars).
I think you could negotiate quite a bit with him. He said at one stage, he bought a USA car where navigation wasn't working, fitted european parts and it worked 100%.
Cheerz
Originally Posted by efandy' post='404927' date='Mar 20 2007, 11:47 PM
Hi there,
U mentioned that the car location was set at Munchen Germany when u 1st installed it & probably because the car is garaged under a tin shed.
Are the display corrected now?
Thanks
Thanks
As soon as I was on the road, I inserted the Australian DVD and was advised that a new version had been detected and to turn it off for 5 minutes, then try again.
When I tried again inserting the Australian DVD, I was surprised that it displayed Adelaide which is the capital city in my state. Since then, the E60 Pro Navigation that I retrofitted myself has worked flawlessly.
There are 2 minor flaws that I hope will get corrected when the E60 goes in for Program v25 upgrade, but with the original Bus Nav re-fitted. Assuming the Progman v25 upgrades the E60 OK, I then have to quickly refit the Pro Nav parts so the v25 Pro Nav retrofit path software upgrade recognises the Pro Nav parts.
I'll keep you informed.
Cheerz
