Subwoofer install. Where is a remote wire?
My Ride: 2004 530i
Hello! there
I plan to add a subwoofer and aftermarket amp.
But I cannot find a remote wire to turn on and off an aftermarket amp.
If you know how to add it or find it, please let's share your idea.
Thank you for all of your inputs.
My Ride: F02 LCI Individual
Model Year: 2013
Taken from another thread on this board (#3 answers your question):
Click here for the thread
I installed a sub, with a separate and additional amp, in the trunk of my car - an Alpine 350 watt sub / amp package.
here are some points raised above....
1) The subs under the seats are really just very good mid range / woofers. Adding a sub will really beef up the bass.
2) Always take sub amp power directly from the battery, for two reasons. Firstly, and foremostly, the power requirement of a sub amp is huge, so you don't want to be overheating any wiring that isn't man enough for the job and having to pester the insurance company after a fire! Secondly, if you take directly from the battery, you can be assured of a "clean" supply, so no buzzing, popping etc...
3) In the trunk, there is a accessory socket - use this as the remote switch for the amp - to turn it on and off - much easier than running a wire from the head unit.
4) E60s are fantastically sound proofed. You need to think about how to get the sound from the trunk into the car - I have a ski hatch, and had a grill custom made to replace the ski bag cassette - exactly the same colour as the upholstery, looks and sounds great.
5) It's really easy to get your speaker level inputs from the speakers in the rear parcel shelf. Just prise the grills off, remove the three screws holding the speaker down, and using somthing like a knitting needle, push your new wire down through the sound proof foam into the trunk.
6) If you are going to secure your sub to the trunk floor, for goodness sake check under all the carpeting / sound proofing to see where your screws are gonna end up - there is a huge wiring loom under there, and the cable that take the battery to the engine compartment.
7) To make the bass sound really crisp, install capacitors in line in your existing speakers. This will omit the really low bass notes from those speakers, meaning that the won't distort, leaving your sub to do the hard work.
Think that's about it....if I think of anything else, I'll post again.
Rob
Rob
Originally Posted by Iceman' post='16850' date='Jul 13 2004, 08:17 AM
Vman33
03-14-2022 04:43 AM
umnitza
09-02-2015 11:28 AM
spediegunz
08-30-2015 09:43 AM
