Anyone ever been to bmw-planet?
My Ride: 540i
Model Year: 2017
I stumbled upon this site and have found it useful. Lots of information for Doing It Yourself.
http://www.bmw-planet.com/diagrams/release...60e61/index.htm
Not me. Damn!
My Ride: 2008 535i Monaco blue/cream beige, light poplar trim, sport, nav, premium, Logic 7, 6 speed manual
My other rides:
Departed: 2006 530xi Silver gray/black, anthracite maple trim, cold, sport, nav, premium, Logic 7, 6 speed steptronic, bluetooth, adaptive xenons
Departed...2002 525i White/beige, 5 sp manual
I don't think so
My Ride: 540i
Model Year: 2017
I know it's the wrong time of year to worry about this, but, I remember this topic coming up a few times. If I read correctly coding at the dealer might solve the problem.
Ice formation on evaporator
Complaint:
the blower of the air conditioning system only delivers warm air after a long journey. Despite the high fan setting, the air flow rate is heavily reduced.
After parking the vehicle for a short time, the function returns to normal.
Cause:
formation of ice on the evaporator after a longer distance driven.
Effect is difficult to reproduce with short test drives.
Service:
In individual cases and after excluding other fault causes, the minimum value of the evaporator temperature can be raised from 0.8 ?C to 2.4 ?C.
This does not noticeably change the performance capability of the air conditioning system. The risk of the evaporator freezing over is significantly reduced.
Information on carrying out the repair:
Vehicles with date of manufacture before March 2005:
On these vehicles, the integrated heating / air-conditioning control panel must be replaced and reprogrammed. After programming, the change to the minimum value of the evaporator temperature must be made via coding of the integrated heating / air-conditioning control panel.
As of version 26, Progman contains the necessary data. Entry via the path Modifications > Evaporator > Temperature > Raise or lower.
Vehicles with date of manufacture March 2005 to November 2005:
On these vehicles, the software of the integrated heating / air-conditioning control panel must be reprogrammed. After programming, the change to the minimum value of the evaporator temperature must be made via coding of the integrated heating / air-conditioning control panel.
Vehicles with date of manufacture December 2005 to February 2006:
On these vehicles, the minimum value for the evaporator temperature is stored in the integrated heating air-conditioning control panel.
The value of the evaporator temperature is raised by means of the service function ?Evaporator control / operating parameters of the evaporator temperature?.
The necessary data is on the Diagnosis and Information System DVD version 43 or later versions. Entry via the service functions at the menu item ?Evaporator control?.
The change to the minimum value of the evaporator temperature cannot be reversed without part replacement.
Before applying the changed minimum value of the evaporator temperature,the diagnosis software checks whether the change to the evaporator temperature has already been made.
If the change has already been applied, ice formation on the evaporator has other causes.
Vehicles as of date of manufacture March 2006:
On these vehicles, the value of the evaporator temperature is not changed via the service function ?Evaporator control / operating parameters of the evaporator temperature?, rather by coding the integrated heating air-conditioning control panel.
The change to the minimum value of the evaporator temperature can be reversed via coding.
Complaint:
Cause:
Service:
My Ride: 2005 545i, Silber-grau/grau. Vanilla flavored except for cold WX pkg.
