Self Installation of Dension Gateway 500
Old 07-07-2014, 08:57 PM
  #71
ntarantino's Avatar
Originally Posted by sdf3kls
You have to tap into the cd changer power source. Mine did not have a changer but the wires are there, both power and fiber optics. If you don't have the cd changer installed you will most likely have to have the system programmed. The stealership will tell you it may not work and quote you $200 plus to update (audio logic has a section on Denison). Take it to your local Indy, mine charged me less than $100 to update the system.
Ok, I definitely have a CDC. I took it out and see the power. The chords have the black connection on the end. With that being said, first time really venturing into BMW on this, how am I tapping into this? I am splicing my chord into this, or whats the approach? Thanks, visually just trying to see this. (visual learner )
Old 07-08-2014, 09:25 AM
  #72
sdf3kls's Avatar
My Ride: 05 545i retired. 11 550i w/sports package
3M (22-18) Wire Taps Red 25 Pcs.
This is what you need to neatly splice into you factory cannon plug for your cd changer.
Old 07-17-2014, 06:01 AM
  #73
ntarantino's Avatar
I have everything working. Audio streams but I can´t get my phone calls to work through the system. Bluetooth streaming audio works though... any thoughts what I might be doing wrong?
Old 07-17-2014, 09:00 PM
  #74
sdf3kls's Avatar
Not sure, I did not get the bluetooth adaptor for my Denison 500 because my 545i had factory bluetooth which would NOT stream audio by the way. I left my Dension in the 545 when I traded it in but I think I still have the box with instructions. I will give them a read to see if I can find anything on bluetooth setup.
Old 07-18-2014, 08:34 AM
  #75
tomstin's Avatar
My Ride: 2004 525i
Not sure if this is going to help. I have a Dension Gateway 500 with BTA1500. When I had my iphone, it paired fine. When I switched to my Android HTC1 M8 I had to pair both the audio and phone functions.
CD6, track 5, press fast forward, that should take you to CD 5, Track 1. Now go to CD 1 track 3 and pair the device as a audio source
CD6, track 6, press fast forward, that should take you to CD5, Track 1. Now go to CD1 track 3 and pair the device as a phone.
As I said with the iphone I didn't have to pair it to both systems but the android I did. Very confusing!
Old 01-22-2021, 05:36 AM
  #76
Dads101's Avatar
My Ride: BMW 525d tourer
Default Dension 500s
I have the connections in my glove box for a cd changer, so I hooked them all up to my dension, but no power coming from the unit, the usb lead where the green light should be on is off after connecting. I definitely have power to the unit and the fibre optic cable is the right way around ( light to left hand side of the unit) . Still can’t get it to work. Help
DarkKnight550
07-10-2012 09:38 PM
bmw_wpq31
123
09-05-2011 01:19 PM
lucienp
07-15-2011 04:29 PM
r9ndy
03-13-2010 12:57 PM
h2009
DIY: Do It Yourself
06-23-2009 04:16 AM
Quick Reply: Self Installation of Dension Gateway 500
