replace "parking lamp"
Old Apr 5, 2013 | 06:03 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
Unhappy Need a little help here
Originally Posted by jayarras
Sorry to resurrect this old thread but I have the same issue, except it's the right side parking lamp malfunction in my case.
Has anyone gone through this that has some pics to share? Also, I'm not clear, should the headlamp assembly come off?
ANYONE?
I discovered that the parking lamp is actually under the H7 bulb. They now have LEDs that you can buy to replace the "5W5" bulb that is listed in the manual. The cross-reference # is 2825 or T10.
So that's it? Use a long nose plier to pry the bulb out?
Old Apr 10, 2013 | 04:27 AM
paran's Avatar
My Ride: 2005 545i Sport
ANYONE?
BMW headlight/parking bulbs are kind of all over the board. My 545i has D2S and D1S style.
The best thing to do is search for exact BMW part numbers using this site: BMW Parts - Authentic OEM BMW Parts direct from BMW of South Atlanta | BMW of South Atlanta type in your exact vehicle and then search for the bulb.
You can access the back of the headlight assembly via the wheel well.
Loosen lugs, jack the car, place it on jack stands, remove tire, now begin removing the 8mm screws that hold the plastic wheel liner in place. Remove as many as needed to gain access to the headlight assembly.
I prefer this method as I don't like to mess with the headlight assembly and its alignment. Also, on a 545i, removing the assembly from the front requires lowering the bumper.
Old Apr 10, 2013 | 04:59 AM
luigi524td's Avatar
Default AE out
Removing the headlight assembly is the easiest way to get at the bulbs ... if you have small hands you may not need to do that. Did you find a replacement bulb the last time you had this problem on the other side? PM me if you need original type AE bulbs - I may have kept mine when I replaced the AE's with bright (and expensive) ones right after I bought my '07 530xi. If that's the case, since I traded my car for an '13 535 if I can find them I'll be glad to sell them to you.
sfcacique
Aug 25, 2025 06:56 AM
DavaiLave
Aug 2, 2022 02:16 AM
Seahawkin03
Sep 26, 2015 11:49 AM
Karmtec
May 5, 2015 03:56 AM
