M5 E60 Cluster
My Ride: M6 F06
Model Year: 2013
I recently bought an E60 M5 Cluster from ebay uncoded. I installed it today and i ended up with many faults. Please have a look at the video (
).As you can see the oil temperature is working too and no transmission fault.
One thing i cant understand, is that suddenly everything stopped working as you can see from the pictures below.
RPM works for a few seconds and then dies, Gasoline also for a few seconds and then dies and so does the oil temperature, but it shows the speed when i put to DS
Do you think a software update will help or is something more than that? Can anybody help me?
My Ride: M6 F06
Model Year: 2013
Originally Posted by my530i' post='449069' date='Jul 18 2007, 02:33 AM
If you know your dealer well, he might help you out on installing this cluster.
Originally Posted by drantispy' post='449065' date='Jul 18 2007, 02:23 AM
I recently bought an E60 M5 Cluster from ebay uncoded. I installed it today and i ended up with many faults. Please have a look at the video (http://www.youtube.com/watch?v=9fr_0XFwK0I).As you can see the oil temperature is working too and no transmission fault.
Have you tried replace it with your standard cluster, so you will confirm that it only needs coding to your car by a ...friendly dealer?
My Ride: M6 F06
Model Year: 2013
Originally Posted by drantispy' post='449074' date='Jul 18 2007, 02:45 AM
i replaced it with my old cluster, but the only thing not working is the consuption. everything else works perfect
The consumption gauge is not working when in neutral, you have to ride the car to confirm.
My Ride: M6 F06
Model Year: 2013
Originally Posted by drantispy' post='449080' date='Jul 18 2007, 02:55 AM
I did that, but it is not working. Also when i disconnect the battery the new cluster goes back to zero. My idrive in service requirements came up with all the messages you see on the picture, but when i connect my old cluster everything disappears.
It's logical, actually the new cluster is not connected to the car. It only takes power and some random signals.
Have you tried the TEST function on both clusters?
Originally Posted by drantispy' post='449083' date='Jul 18 2007, 03:08 AM
Fair enough. You say is not possible the new cluster to work ?
SBT__E60__E61__E63__E64____915___949___957___953___954___941___962____965___960___959___948___94.pdf
and this
SBT__E60__E61__E63__E64____916___953___940___947___957___969___963___951____947___953___945____9.pdf
