Ignition signal
Can anybody give me an idea where to get the Ignition signal (power when Ignition is turned on) in the trunk? I need it for the remote signal of my amp. I don't have the standard amp in the car and the best place to get it might be the fuse box.
I have searched the WDS and the forum but could not find the information. Only guess would be to take it from the cigarette-lighter power output, but fuse box fould be more comfortable for me.
Any ideas or helpful links??
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
Dirk,
It's OK to grab cigarette power line to turn on your amp. It's already has the fuse for it. Also, the remote turn on is just an input of a relay inside your amp. If you're afraid, you can grab power from cigarette lighter, going through a fuse, the input to the remote on.
I feed power from cig lighter directly to my amp remote-on input.
Fred
Fred
thanks my530i and bruce-miranda. That helped a lot. I weired fuse 87 yesterday. I'll see if the battery still has power this morning. The Cigarette lighter fuse 82 would be my second choice if it does not work. I would prefer the 87 solution as amp would be on power with no need of motor power on.
Wonky
04-12-2016 08:15 PM
