How To Remove Rear Emblem Safely
Old Sep 1, 2007 | 05:36 PM
mtw1116's Avatar
My Ride: E60 Bimmer, Sports Package, Premium Package, Black/Black, Xenon Lights, 20
Model Year: 2005
Anybody know how to remove the rear emblem (530i) on your E60?
Old Sep 1, 2007 | 07:34 PM
nigxdoof's Avatar
Use cloth and wedge a flathead screwdriver and pry and pray. hahaha.. good luck
Old Sep 1, 2007 | 08:09 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Like this:
replacing_rear_BMW_badge.pdf
Old Sep 2, 2007 | 08:13 AM
subarashi's Avatar
My Ride: 2005 545i E60 Orient Blau Metallic Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
Originally Posted by Rudy' post='464951' date='Sep 1 2007, 11:09 PM
Like this:
Attachment 37048
Hey Rudy - that PDF just says you replace the rear like you do the front! It's a matter of prying with a piece of thin cardboard [like a shiny, plastic visiting card which is what I used], under the emblem with a screw-driver. You will prob scratch the paint a little bit but this will end up covered by the emblem in most cases.
BTW - thought I should mention this here. The STEERING EMBLEM install is a simple STICK ON TOP of the old one. DO NOT TRY TO PRY OUT YOUR STEERING WHEEL EMBLEM. It is held in place via prongs that wrap around the leather and sit under the steering. I found this out the hard way and now have a lot of scracthes on my steering wheel where I forced the screwdriver under to try to pry it off. The solution? Simply put two stick on emblems so that it stands out more and distracts attention from the minor cosmetic blemishes.
Hope this helps..... Why isn't anyone answering my M5 Aero Install DIY help thread?!?
Old Sep 2, 2007 | 08:17 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Ooops. That's what I get for not posting both the front and rear instructions together (as I did a while ago in another thread...)
Here's the front one:
replacing_front_BMW_badge.pdf
Old Sep 2, 2007 | 09:26 AM
mtw1116's Avatar
Model Year: 2005
OOhhh What I Meant Was How To Remove A Rear NUMBER (525, 530, 545, etc) emblem on the back trunk of E60... And I thank You For The Help who Ever Responded.
Old Sep 2, 2007 | 09:31 AM
subarashi's Avatar
Hmm..we're gonna have to work on our communication there mtw116!
Here you go...these links should help you...
http://forums.e60.net/index.php?show...29406&hl=badge
http://forums.e60.net/index.php?showtopic=3674&hl=badge
http://forums.e60.net/index.php?showtopic=103&hl=badge
E60Japanese
Jan 20, 2025 04:23 PM
Awest91
Sep 17, 2022 11:05 PM
rteone
Apr 7, 2015 11:48 AM
Sibby1979
Mar 18, 2015 05:27 PM
