DIY ZF 6HP19Z Transmission Drain & Refill
#251
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron"
SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR
2003 Audi A4 3.0 CVT "Part of the Moniker"
Silver/Ebony, Prem, CW, Star 17s
Finally did a second drain and fill, about 2k after the first drain and fill (changed filter with the initial flush). Now at 64k. Runs great and seems even smoother.
Gets easier to do with experience. Used pentosin.
#252
Does anyone know if the information in this thread, which started as a 535i thread, would also apply to my 535xi wagon?
I posted in the E61 wagon forum, but due to the traffic level there, I might not get an answer.
My concern is whether there are any differences owing to the xi's AWD transmission, and/or the wagon setup (larger capacity, or maybe auxiliary transmission cooler? I don't know).
If anyone has any knowledge of differences, I'd appreciate it.
Also, has anyone changed the fluid in the differentials? I'd like to do this as well (I'm at 100k miles).
Thanks,
Sarge
Thanks,
Sarge
#253
Experts can chime-in, based on my readings, I understand that the transmission is the same on all E60/E61. So you would have the same pan/filter/fluid. I was advised to use the ZF tranny fluid only (good price at Bavauto.com).
The AWD systems would have front transfer case and rear differential which would use "gear" oil. I was impressed with the car-specific recommendations for oil/parts that bavauto provided on their site. you would likely be able to know the oil needed for your transfer cases.
#254
My Ride: 2004 525i
Engine: M54
![Question](https://5series.net/forums/images/icons/icon5.gif)
WARNING: ZF has strict temperature requirements for fill. As per ZF, when adding new fluid while the engine is running, the temperature of fluid should be at 40 deg C. Oil temperature MUST NOT exceed 50 deg C. If the temperature gets past 50 deg C, you must allow transmission fluid to cool down before you start the fill procedure again.
#255
What you do is fill it as full as you can first then start it and continue filling. When the engine isn't running the fluid will start to come back out of the hole well before you've reached the correct level.
#256
Read Raj's post.
1st fill is with engine off. When fluid starts coming out put the fill plug in only to stop the oil and not too tight. Start the car and run thru all the gears two seconds in each. Twice. Including reverse. Totaling warming time is approx 5 minutes. At the 4 minute mark get under the car and ready your filler and unscrew the fill plug. At 5 minutes start filling until the oil oozes out again. Put in screw quickly and torque to spec. If you botch the fill (as I did the first time as my fill hose came off), let car cool for one hour. Then run thru the gears as before and refill. (You cannot do a cold fill with engine off as there is oil in the pan) As the oil still was warm from the earlier fill, I went 3 minutes on the warm up. Not sure about the precision here but it worked. The best precision is using a heat scanner or measuring oil removed exactly. Again Raj has a nice post.
I plan to change again at 90 or 100k. Got the hang of it now.
#257
Did the diff at 60k along with the tranny oil. Oil was a bit dark. Used mutol oil.
You'll need a big allen socket and pump. 1.75 quarts or so. Driveline felt sharper but maybe my imagination. The easiest DIY short of a oil change.
#258
My Ride: 2006 BMW 530I
Model Year: 530i
Thanks for the info!
Sorry if this sound like a stupid question, has anyone done this (successfully without lack of space or leverage) on four standard jack stands? Will the height of the jack stands be good enough for a 5'8, 165 pound guy to work under? If not, much weight do I need to lose? :-)
#259
My Ride: 06 550i
Model Year: 06
Are the pics from the OP showing up for anyone? I posted a topic about it and the admins said it was fixed and I still cant see them. I want to make sure my account isn't jacked.
#260
Used rhino ramps on the front and jackstands for the rear. Car driven on ramps, and then jacked at the center diff to fit the two jackstands for the rear. Used esc tuning inserts on the square jacking points.
Plenty of room and takes a little eyeballing to get it level. Also used another jack under the engine to elevate the front an extra inch for room and to tilt the car to get more oil out. Ramps really give you the extra sense of security under the car.
