DIY LCI tail light retrofit (cheaper method) Verison II
Old 03-04-2012, 08:12 PM
  #61
turboawd's Avatar
My Ride: 2006 BMW 550i
Originally Posted by shongcave
I am interested in this cable , would u mind leaving me your contact through pm
you need 5 posts to send a pm.
Old 03-06-2012, 05:33 AM
  #62
shongcave's Avatar
Ricky
the second one has one more connection to the LED , is that necessary?
Old 08-31-2012, 01:58 AM
  #63
Wman's Avatar
I am from Hong Kong.
How are I get the lci cable? Is it come from the OEM lci light ?
Thanks
Old 08-31-2012, 05:56 PM
  #64
ricky1329's Avatar
My Ride: 530i Mods: M5 sporty package, M5 Steering wheel, Sprint Booster
Thanks
Hi Wman,
Please find below thread for DIY LCI cable https://5series.net/forums/topic/882...&#entry1041049
It would not come with LCI tail light.
Best regards
Ricky
Old 11-01-2012, 01:22 AM
  #65
wnshie's Avatar
For the members in Hong Kong, if you want it done, please try to contact AK thru 64989348 (after 3pm), he is more than happy to help (I am getting no commission out of this! )
Old 11-17-2012, 06:15 AM
  #66
am_pm131's Avatar
Originally Posted by ricky1329
Update the photos, drawing and BOM for reference. ( I take no responsibility for any guys whose like to follow, Guys take your own risky )
DIY Cable set:
Attachment 99873
Attachment 99874
Circuit diagram:
Attachment 99875
BOM list: ( the largest 20W resistor can use 20R; 22R or 25R )
Attachment 99876
I have a 2008 535, do I need the circuit board still? If not, can u pls explain one more time what materials are needed? Thanks
Old 12-19-2012, 04:25 AM
  #67
KOC
KOC's Avatar
My Ride: E60
Model Year: 2016
Hi Wman,
Please find below thread for DIY LCI cable DIY LCI tail light retrofit (cheaper method) Verison II - 5Series.net - Forums
Best regards
Ricky
Really followed this thread 100 times....tried a set from one of your followers....and also asked my colleague to solder a set....same suituation:-
When i took out all four bulbs, error code....but all lights function as Ricky's effect. I tried and managed to put back each side one bulb at the outer bulb holder, then no error (If I put the bulb in the inner bulb holder, reverse light came up too, so I put back at the outer, if put back both, still got error).....In order to avoid error in i-drive, my case is funny and became a specail effect :-
Without light on - when brake, the outer bulb, led rods and fog on;
With light turn on - without brake, outer bulb on, led rods on;
when brake, outer bulb on, led rods on, fog lights all on!
In all cases above. turn lights and indepentant fog light get no problem. I tried all 20w 20, 22r, 25r power resistors.....lights bulb in place, no error, take out bulb, error.....need to try other watt resistor?
Photo shows - turn light on without brake, outer bulb on, led rods on.....
Attached Thumbnails DIY LCI tail light retrofit (cheaper method) Verison II-img_0494.jpg
Old 02-18-2013, 03:02 PM
  #68
BallyM5's Avatar
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic, Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release, Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
any one willing to make one set of these for me if so how much thanks
Old 08-26-2013, 01:28 PM
  #69
pluto2013's Avatar
My Ride: E60
Is this only for LM2? or will this work with LM1?
cheers
Old 08-26-2013, 07:32 PM
  #70
bimma328's Avatar
i just finished my conversion with a LM1, i will post some details and pics after! cheers!
Quick Reply: DIY LCI tail light retrofit (cheaper method) Verison II
