DIY: E60 Sport Automatic Retrofit Redux
Old 01-05-2017, 09:06 AM
  #111
535iHI's Avatar
My Ride: 535i
Default Confirm information?
Just got my 2008 535i with sport package (no Sport Automatic Transmission (SAT) or paddle shifters) and just joined the forum. Thanks all for the information here.
I am very interested in the SAT (quick shifting and rev matching) but of course want to do it as economically as possible. I don't care about the paddle shifters or the updated shifter look. The information from the OP is laid out well but I just wanted to confirm that there are no more recent updates to that info. Questions I still have are:
1. I know the SAT ECU (PN 61319165671) is required but is the SAT shifter (PN 61319142950) required too or does it just look nicer? Will the non-SAT shifter work on the SAT ECU?
2. Is the Sports button (PN 61319142869) replaceable with the "Sports button Hack" (i.e. connecting the momentary switch between pins 8 and 10?)
Thanks!
Old 01-05-2017, 04:32 PM
  #112
Honza's Avatar
My Ride: 2008 535xi
Im confused on firts page of this post are diffrent part numbers than you wrote..Which ones are right? for 535xi 2008... Thank you
Old 01-06-2017, 08:25 AM
  #113
535iHI's Avatar
My Ride: 535i
Disclaimer that I'm not an expert but putting these part numbers into realoem.com it looks like there are a bunch of part numbers for the SAT and over time part numbers have been superseded. I can't answer what's needed in order for it to work for your car but these are the parts which make up the SAT.
I believe the part numbers, including older part numbers, are:
Shift box, gear selection switch:
61319149501
61319165671
61319174980
61319189640
61319204093
61319212220
61319191206
61319224210
61319213650
Selector lever handle
61319142950
61319208271
Sport switch
61319142869
Cover, gear selecting lever
51166960879
51166985886
Old 01-06-2017, 08:46 AM
  #114
Kewill0360's Avatar
My Ride: 535XI
Engine: N54
Supersede or not is all the same, different part # for different cars.
Old 04-25-2017, 10:38 AM
  #115
Honza's Avatar
My Ride: 2008 535xi
Default Cant find right file
Hi, i just got hardware installed to my car..my friend did some coding..so sport shows in cluster but he was not able to find right file to flash the transmission. I have 535xi so u would use file from 535i. i see non sport files but cant find nw13 7601458...he said he has the newest file...I dont know anybody can explain or post link to get those files. thank you!
Old 07-06-2017, 10:40 AM
  #116
Johnny Lankford's Avatar
My Ride: 535I twin turbo basic for most part.. FAST
Default Sat
Originally Posted by terraphantm
One major aspect this retrofit is missing is reprogramming the actual transmission module. The sports auto and standard auto have different software.
Using WinKFP, I flashed my standard auto (in a 535xi) to the sports auto software (in the case of the 535i, it's 7601458 as of Ista/P v41.. may have changed in newer releases). I had to clear a few errors in the DSC, EGS ,and DME, but after that the car had no complaints.
The transmission still works, and it feels like it shifts faster, particularlly in S and M modes. It's also a lot more aggressive about downshifting in S mode. I did *not* change my VO, nor did I recode my KOMBI (partly because $2TB was never an available option for the xi models). However, my KOMBI is behaving differently now; when I'm in S mode, it displays the gear the car is in instead of just simply showing "DS" - I will probably try adding $2TB and see if my KOMBI accepts it.
I have not retrofitted the sports shifter (yet), so I have not been able to test the actual sport button. But even without it, it's a pretty nice upgrade. And it does seem to work properly on the xi despite it never being available officially on the RWD models.
EDIT: Well the car did accept the $2TB VO without complaint, and I was able to recode the KOMBI without issue. The FSW_PSW does show changes, but I cannot say I actually notice anything different with the recoded KOMBI.
Great write up. Have an e60 535i and want to code for sat. Do I need to buy the retro kit for it to work or will coding through NCS do the trick and work? Don't care about the button. As long as i can kick the shifter to ds mode which through kombi coding should reflect S1-S6 instead of m-1 through m-6
Old 07-06-2017, 11:12 AM
  #117
can I code SAT to work without sport button. Have 535i e60 and steptronic ds mode..
after coding and if it works should read s1-s6
Old 01-10-2019, 10:25 AM
  #118
tryingtobebest's Avatar
My Ride: 09 335d
Model Year: 2009
Engine: m57
I know its not the right forum but I have an X5 and trying to find SAT firmware that will work on it!)
This is my car according to Ista/d and bimmerarchive (Prod. Date 2009-12-13):
“ 2008-01-2010-02/FF03/X5/3.0sd/SportsActivityVehicle/M57D30T2/210kW/All Wheel-Drive/left/USA "
( https://www.bimmerarchive.org/e-code/e70.html )
And this is ID of transmission and current soft:
( HW-7605219 SW-7608706 )
I did my research in "GKE195.ATS" file from "E89" Daten (version 60.1) files! It looks like GKE195.ats file from E70 looks the same, also im not sure if i should redownload any DATEN from other body styles that listed below and check this gke195.ats file in them for different information. Following body abbreviations from bimmerarchive.org i found only few vehicles that have the same M57 engine (NOT sure about transmission hardware part) that have 2TB option so im thinking they have SAT firmware. Still researching this hard.
2006-05 - 2010-01/EA71/635d/Coupe/M57D30T2/210kW/Rear-Wheel Drive/left/Europe
From GKE195.ATS file = “EA71;;2TB;7592148;SE”
2005-11 - 2009-12/NX91/535d/Sedan/M57D30T2/210kW/Rear-Wheel Drive/left/Europe
From GKE195.ATS file = “NX91;;2TB;7592134;SE”
Is option 2TB automatically comes with SAT? None of the Diesel AWD M57 cars that i found had option 2TB!!!?(
PLEASE advise.
Doing my own research on other forums, thread are left unanswered:
Bmw coding forum (need registration) - E70 Paddles and SAT retrofit questions
Bimmerfest - E70 Shift Paddles on steering wheel and SAT retrofit programming and coding
5series.net post#867 - Sportautomatic (SAT) retrofit
Others
Old 01-16-2020, 11:12 AM
  #119
Redballs1's Avatar
My Ride: 530d msport Lci 2007
Default Successfull retrofit
So the last post on this thread was a year ago, but i wasn’t aware of it until a couple of weeks ago. I was curious about fitting the SAT shifter purely for the aesthetics so started googling around and came across this thread. I already had a bit of experience with ncs-expert. So with the info from this thread i used winkfp to flash my gearbox with a 2TB file and coded the necessary modules with ncs-expert. To gain sport function over and above DS mode i wired in the switch behind the fusebox. So i haven’t changed any hardware except the addition of a button but i believe i have full functionality. S1-S5 in DS mode and sport in the display when button pressed, the difference when pressing the button is remarkable. So now i have to get some money together to buy the proper hardware and maybe a new paddle equipped steering wheel. Purely for aesthetics.
Johnnyfive
07-03-2017 10:14 AM
creeping_death
06-06-2016 03:03 AM
biz77
08-02-2015 04:10 PM
epilithic
10-25-2012 08:49 PM
dantheman1
08-03-2011 09:47 AM
Quick Reply: DIY: E60 Sport Automatic Retrofit Redux
