2004 545I - IBS Cable - New Part number?
Hi,
I have a 2004 545I. I just found out (from dealer) that the IBS cable of the car is faulty. So I ordered the negative cable from getbmwparts.com.
And instead of sending me the cable with part # 61 12 9 184 203 (IBS cable for 04 545I), they send me the cable with part # 61 12 9 215 949
When I pointed it out to them, they said that it is the direct replacement of the old part and old part (part # 61 12 9 184 203) is no longer available for purchase.
So I contacted my local BMW delearship to confirm because I do not want to put the wrong part in the car which can potentially damage the battery system. The local deaearship told me that the old part is still available for purchase and the new part is just for the newer 5 series cars and it may or may not work with 2004 models.
So I am now confused and I am not sure what to do.
Can the experts here tell me that if I can use part # 61 12 9 215 949 in '04 545I?
Thanks,
Bhavi
Edit: Mods, Please move this topic to appropriate forum is it does not belong to this forum.
Thanks,
Bhavi
Hi,
Thanks,
Bhavi
Thanks,
Bhavi
i had this replaced before.. how do you know its faulty? what error lights are you getting?
My dealership qouted me $1200 to replace both (battery and cable). So I decided to change it by myself. I got the battery from Batteries Plus and I ordered the cable from getbmwparts.com. But I believe I got the wrong part.
i have the same issue, except i got a passenger airbag failure, and the dealer told me its the IBD cable. That was the only error or issue i had. Still havent replaced it since they asked for $400, but i would love to know how to?
I had the check engine light on and I was having "Increased Emissions" error in I-drive. So I took the car to the dealer and they found a bunch of fault related to battery. They diagnosed that the battery and the IBS cable are bad. I also know that there is something wrong with battery/IBS because the battery does not hold chanrge and I have to crack it hard to start the car every time I start the car
usually ibs cable is linked to airbag issue or battery. i had this changed cause one of my airbags were blown out. increased emissions usually relates to emission issues only.
So back to my original question, does anyone know if the negative cable with the new part number can be put on 2004 5 series?
My Ride: 2004 530i,Titanium silver,cold weather package
Talk to Garry @ NewportBMW,they have a post on this site.Garry took care of me this past winter with one of those(IBS sensor).Also the part take an adapter,and reprograming by stealership.Garry gave me 25% off,everything (minus reprograming) with s/h was like $175.
The $175 for IBS cable and adapter is a very good price indeed (I paid ~$250). Next time I will probably get the parts from Garry. Also I do not think we need to reprogram the car to just to change the battery cable. But I could be wrong.
My Ride: E60
Engine: N52
Stealer said my IBS cable crapped out a while back but I didn't want to pay the $400+ bucks they wanted since I figured it couldn't be too difficult.
I just want to cover my bases though with the install.
Is there a DIY available for the IBS cable/adapter?
Is programming honestly needed for a cable change?
Sounds like BMW's "registering" the battery BS...
DavaiLave
08-02-2022 02:16 AM
BYS2
03-24-2015 03:13 AM
