Car Coding
Old 03-22-2013, 03:01 AM
  #711
F-Tar's Avatar
My Ride: BMW Alpina B5 -05
Sorry, OFC i meant "BEIKLAPPEN_B_KOMFORTSCHL"
Old 03-22-2013, 03:16 AM
  #712
BLooD's Avatar
Originally Posted by F-Tar
Thank you! Sure you have comfort windows aswell working on ur car if holding close/open keyfob for a longer time right?
KGM:
Then--> BEIKLATTEN_B_KOMFORTSCHL <-- it is!
I will activate this value only then.
Yes all UK E60`s had comfort opening/closing of the windows as standard.
Old 03-22-2013, 03:41 AM
  #713
F-Tar's Avatar
Yes my 2004 has it aswell! Not SA430 tho
But thanks all! Now i think i know all i need to activate folding mirrors
Old 03-22-2013, 03:58 AM
  #714
BLooD's Avatar
ermmm if you dont have SA430 auto dimming/folding mirrors then you need to fit the mirrors, activating the functions will do nothing with out the mirrors.
Old 03-22-2013, 05:09 AM
  #715
F-Tar's Avatar
If u take a look back in my previous posts you'll see that this function is going to be activated on a 2006-05 E60 equipped with SA430 i wish i had SA430 on mine, don't even have KGM module.
Old 03-22-2013, 05:10 AM
  #716
F-Tar's Avatar
Thank you for helping me out!!
Old 03-27-2013, 05:50 PM
  #717
AchtungE60's Avatar
My Ride: E60 530i
You do have the module it's just probably called something different. Perhaps KBM? It exists on the K-CAN bus.
Old 03-28-2013, 02:32 AM
  #718
BLooD's Avatar
On the early E60 2003 - aug/2005 there were two door modules that controlled the mirrors, from sept/2005 these were replaced with the KGM module.
Old 03-28-2013, 04:20 AM
  #719
F-Tar's Avatar
Yes i have KBM, But my mirrors are stiff and i cannot fold them :/
Old 05-16-2013, 10:02 PM
  #720
mrdunu's Avatar
Originally Posted by BlaSTiWi
I tried them but unfortunately it didn't look like the LCI ... when aktiv the _2_ setting didn't do anything and the _1_ light up the rod but along w/ the 2nd bulb in the middle (next to the rear fog) but in brake (bright) mode all the time.
I'm starting to suspect it maybe 'cuz of my 'hybrid' conversion that alter the behavior I want. It makes it kinda hard as the car came w/ LM2 and LCI tails w/ Bruce's cable & Halogen -> LCI non-Adaptive headlight w/ wire hack conversion.
Now that I'm getting familiar w/ NCS maybe I should just do the full LCI front+rear lights conversion when the weather get warmer .
I seem to be experiencing the same issues as you are in this post.
Did you end up finding a fix for it?
Ideally i'd like to set my LED Rods + the bulb thats nearest to the trunk, but I haven't been able to find a coding combination that works!
If it makes any difference, I have a 04 525i with an LM2 and LCI tails w/ Bruce's cables (but mine is factory Xenon).
Thanks
Quick Reply: Car Coding
