Car Coding
#701
My Ride: BMW 525dA 2007 pre-LCI.
Def not if you don't have a LM2 module. With an LM2 i doubt there is an option to use fog's as DRL. Since it isn't legal BMW hasn't forseen this as on option .
#703
My Ride: 535xit loaded
progman error
"the connected vehicle has unknown data status (5.22, UNBEKANNTE_I_STUFE), witch can not be handled with progman!
Make sure you have loaded the latest version of Progman CD or contact your Technical Support." .
I have inpa,ncsexpert,disv44,disv57,progman running perfectly for my e39,e46,and e53.
I get this error with my new 2008 535xit.
What is wrong?
I am using the good $100 version cable with inpa/dcan
What is wrong?
#704
What is wrong?
What is wrong?
#705
My Ride: BMW Alpina B5 -05
I want to enable folding mirrors via keyfob on a E60 equipped with SA430.
Is this the only value need to set to "aktiv":
BEIKLATTEN_B_KOMFORTSCHL ?
In KGM module.
Comfort mirrors via keyfob is already activated from factory, it this something i need to disable or should i let it be "aktiv"... i mean these 2:
KOMFORTOEFFNUNG_FB
KOMFORTSCHLIESSUNG_FB
Thanks
In KGM module.
KOMFORTOEFFNUNG_FB
Thanks
#706
Yes BEIKLAPPEN_B_KOMFORTSCHL is the only thing I made aktiv.
But do you have KGM module? I thought KGM is on after Sept. 2005+ production car.
Careful with the spelling too.
I didn't have the other functions you mentioned in my KGM so no idea 'bout them.
In KGM module.
KOMFORTOEFFNUNG_FB
Thanks
In KGM module.
KOMFORTOEFFNUNG_FB
Thanks
#707
Do you have comfort close windows via keyfob as standard? How is that function affected? I don't want the windows to roll down when i hold the locking button as the mirrors folding in. That's why i ask if comfort close is needed to be disabled? Or It's maybe the right opposit? Comfort close windows must be activaed for enable folding mirrors.
This is for a e60 2006-05
#709
Okey. Thank you for ur relply
#710
KGM:
Then--> BEIKLATTEN_B_KOMFORTSCHL <-- it is!
I will activate this value only then.
